2004---Changing front Hubs/wheel bearings
Old 23 Nov 2013, 04:48 pm
Default 2004---Changing front Hubs/wheel bearings
After you remove the steering knuckle, does the hub come out of the knuckle without having it pressed out? I know the bearing needs to be pressed out, but I was hoping if I replace the entire hub to avoid having to take it to a Machine shop. Thanks in advance.
Old 23 Nov 2013, 05:03 pm
Default Re: 2004---Changing front Hubs/wheel bearings
You have to press it out of the bearing Then the bearing out of the knuckle.
Front wheel bearings screenwiz Turbo Wheels/Suspension/Handling 5 19 Dec 2012 12:58 am
Front Wheel Bearings L2fish Wheels, Tires, Suspension 0 18 Dec 2012 08:19 pm
Changing wheel bearings, Press required? gevans Wheels, Tires, Suspension 47 17 Jun 2011 02:28 am
How many front wheel bearings? scrisp2 Wheels, Tires, Suspension 0 22 Mar 2010 11:24 am
Changing wheel bearings 52smooth Wheels, Tires, Suspension 2 11 Apr 2008 02:19 pm
