Another starting problem
Like Tree2Likes
Old 25 Nov 2013, 08:03 am
Default Another starting problem
Hello...i searched for similar problems but could not find one so I apologize if this has been discussed before.
I have a 2002 PT Cruiser. I went to start it yesterday and I heard a clicking noise once and then EVERYTHING shut off. I could not even get the power door locks to work. I thought it might be the battery and was going to get a new one today but out of habbit I hit the unlock button on the remote and the doors unlocked. I opened the door and the lights came on so I tried starting the engine. The exact thing happened - one click and everthing went out. A few minutes later the remote was working again and I was able to put the key in the ingnition and turned on all the electrical stuff (radio, lights, etc.) without an issue. But when i tried to start it, everything went out again but power came back a few minutes later.
Any idea what it could be?
Old 25 Nov 2013, 08:35 am
Default Re: Another starting problem
Simple...it's like you thought, the battery. Everything else on the car, lights, radio, remote etc., takes very little power from the battery. The starter needs almost the entire power of the battery to turn over the engine. That's why everythng else works and it won't turn over the engine.
Give it a jump start or power pack boost and get it over to any decent auto store where they will give you a FREE battery/charging system check....and then sell you a new battery.
Old 25 Nov 2013, 09:10 am
I have to agree with Crewzin, your battery is so low that when you attempt to start it, the battery only has enough power, from the sound of it, to pop out the starter solenoid, but it's obviously not got enough power to turn the flywheel. Probably have a bad cell or two in that battery. Mine was doing something very similar about 8 months ago. I bought a fancy charger and was bumping the battery so the engine would run, then within two days it wouldn't start again so I'd bump it again. Finally figured out my battery wasn't holding a charge, had two bad cells, got a new battery and not had the same problem since.
Old 29 Nov 2013, 06:42 pm
randyincctx's Avatar
Question Re: Another starting problem
Mines NOT starting now......This morning turned the key,and heard 1 strong 'ker-chunk' from the starter solenoid(not 'click';or 'click,click,click')....But,I hooked up my Ford Ranger w/jumper cables anyway,and still got the same result.
Everything has good power,headlights,door locks,radio,HVAC blower,etc.
Took column apart checked,Ign. switch & actuator,checked starter relay(swapped w/horn relay),and checked fuses in PDC also.....So,based on the 'strong' sound coming from the solenoid,it's obviously getting plenty of power to the solenoid.
I'm starting to think it may be the root of the problem(or the whole starter?).....Conferring,or opposing opinions?
Aka:~KILLER~
Old 29 Nov 2013, 06:59 pm
Too much to type....calling you
randyincctx likes this.
Old 29 Nov 2013, 08:06 pm
I think its the starter. Cleaning your major grounds would be a good first step.
Old 01 Dec 2013, 01:29 pm
Thumbs up Re: Another starting problem
BINGO!!!!......We have a winner!;Now that I had a handy assistant to turn the key,while I'm under the hood(Thanks Dad!),I had him start 'bumping' the key,while I used a 1x2 & hammer to 'rap' on first the starter solenoid housing(3x),and then on the starter housing itself.....On the third bang on the housing.....'Vroom-Vroom!'
I'm letting it idle for a bit,to assure any charge that was drained is replenished.
I find it strange that it worked fine the other day,and then after this last 'chiller' of a cold snap we had....I got 'nada'?(I've seen where others had mention the same conditions.)
Aka:~KILLER~
Old 01 Dec 2013, 09:00 pm
fy9-03pt's Avatar
Has anyone heard anything from rockingordo about his problem ? wondering if he ever got to the bottom of his trouble.
Darn he posted his problem then everybody went to the help of everybody else .
Robert
Old 02 Dec 2013, 01:42 am
Randy; I also think it's the starter/solenoid. You can pull the starter out and remove the solenoid from it. Sometimes the large current contacts inside the solenoid get burned out. I don't know if the solenoid is available as a separate item. good luck.
Old 02 Dec 2013, 01:56 am
Red face Re: Another starting problem
Yeah,I'm a victim of 'sticky-solenoid' syndrome.....I saw the solenoid for as low as $30,but in order to replace it,I have to do almost the same amount of work as doing the whole starter($120 @ A/Z-$90 w/core return);But,I sure would hate to change just the solenoid,do all that work,and then 6 months-1 year later,have the 'old' starter begin messing up.
Aka:~KILLER~
starting problem skinnyp Tech & Performance Forum 10 09 Apr 2016 04:46 pm
06 starting problem rhythmbone Tech & Performance Forum 8 23 Jul 2013 05:54 am
Starting problem Elrodion Tech & Performance Forum 0 18 May 2009 07:49 am
01 PT Problem with starting car Vengence General PT Cruiser Discussions 1 04 Apr 2009 01:29 pm
starting up problem packrat007 Tech & Performance Forum 11 15 Aug 2008 04:38 am
