check engine light
Old 30 Nov 2013, 06:49 pm
edscrz's Avatar
Default check engine light
Check engine light came on about 5 days ago. I will occassionally blink a few times then stay steady on. Car has been running ok since. Code is P0302. I only comes on when I am idleing in park at the drive thru at the bank or the pharmacy when I go there direct from home ( less than 5 minutes away and engine is cold) This may happen every couple of months or so, I just undo the battery for a couple of minutes to reset the code. Should i be concerned? edscrz
edscrz
Old 30 Nov 2013, 06:54 pm
Default Re: check engine light
You didn't say if you knew what the code means. It's a misfire on cylinder 2. Could be as simple as a small vacuum leak around that cylinder on the plastic upper manifold seam or where the rectangle rubber gaskets seal the upper and lower manifolds. If your having no problems, maybe it won't get any worse but I would think it would and eventually you will have a rough idle or stumble when driving.
Old 30 Nov 2013, 06:58 pm
edscrz's Avatar
Thanks, I did know what the code is. The odd thing is this only happens when at the covered drive thru.
edscrz
Old 30 Nov 2013, 06:59 pm
Don't think that has anything to do with it ....but you never know, stranger things have happened. Other things that you can check are the "O" rings on cylinder 2 injector and if possible, have the engine compression checked to see if there's any internal damage.
Old 30 Nov 2013, 07:06 pm
edscrz's Avatar
I've had this happen off and on for about a year and a half. Car runs fine and usually idles ok. I don't think will worry about it. I was just wondering if something with the exahust when idleing in the confined area could be causing the problem.
edscrz
Old 01 Dec 2013, 08:35 pm
fy9-03pt's Avatar
I was told that when the engine light blinks on and off then stays on that it was something that had to be fixed. Most of the time when the light stays on it is letting you know you have a problem .
Robert
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
check engine light edscrz Tech & Performance Forum 0 12 Mar 2012 01:16 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
