I want to remove my shift knob and replace it with something else. Is the pole threaded? Because i understand that the factory knob is on with a spring. If so, what size are the threads and can i just directly screw on any fitting knob without any adapters? Just let me know everything ill need to replace factory. Thanks alot!
The knob and shaft are not threaded.
The 5-speed gear shift knob is press fit into place. Sufficient upward force will remove it. I use a small rubber mallet to strike the shift knob from below. I've read the suggestion to pad an open wrench, placed below the knob, and then hit the wrench upward. Once off, you will see how it works. Good luck. Quote:
Can someone direct me to a place that sells shift knobs that will fit my car?
Flameball Shift Knobs
I have a blue and white light up knob from these guys, been in the car for 12 years now and still looks as good as the day I put it in! I used a small dab of epoxy to hold it in place, just enough to hold it but I can still remove it if necessary.
Joel ![]() 2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1995 Caprice Classic woody www.rcktpwrd.com |
When you knock that stock knob off by striking it from underneath, wrap a rag over the top of it and hold on to a couple corners of the rag. Otherwise the loose knob will hit you in the eye or fly into the sunroof or overhead.
Because the shift lever is not threaded, you will have to find a knob that has a hole that is the exact size or drill out a smaller hole to size and glue it on. Your other option is to buy the adapter available on eBay. It has a master 16mm - 1.5 stud at the top which is a very common thread found on many shift knobs and it attaches to the lever with 3 set screws...... Polished Shift Knob Adapter for Manual Auto Short Throw Gear Shifter Selector 2 | eBay When I use one of those, I drill through the plastic spacer and make a dimple through all 3 holes into the lever. You can try and skip the dimple drilling but the knob is liable to be constantly lose if you don't. You can thank Mother Chrysler for all the hoops you will have to jump through in order to have a custom knob. Last edited by 2step; 04 Dec 2013 at 04:42 pm. |
I ripped my shift knob off racing an intrepid from a redlight. I was laughing soooooo hard. I mean who woulda thought... Yank it into second, the ball's in the backseat.
That's how I learned it wasn't threaded. Didn't find the forum yet ![]() |
![]() Quote:
![]() ![]() Jerry |
Tags |
manual, shifter |
Thread Tools | |
Display Modes | |
Manual shift knob | atracats | Interior Accessories Forum | 10 | 30 Sep 2011 09:21 pm |
Shift Knob | deafy06 | Interior Accessories Forum | 8 | 20 Aug 2011 01:43 pm |
02 PT Cruiser manual shift knob loose | salvi | Interior Accessories Forum | 1 | 18 Jan 2011 12:54 am |
Shift Knob | air4cefamily | Interior Accessories Forum | 3 | 15 Jun 2008 09:23 pm |
OEM Shift Knob | zzzhuh | General PT Cruiser Discussions | 5 | 05 Apr 2004 10:59 am |
