Below Zero Temps and Unable to Start
Like Tree11Likes
Old 06 Dec 2013, 06:31 pm
Default Below Zero Temps and Unable to Start
Hi!
I need help with my 2006 Base PT Cruiser. It has been below zero for 3 days in a row. The first couple of days, my car had a hard time starting. Now on the 3rd day, it just clicks. I have tried to jump it but and the starter is turning over, however, it will not start. While trying to jump it, there was a smell of gas, but I have a 1/2 tank. I am thinking possibly a fuel pump?
I am trying to locate the fuel line and the fuel gauge test port to see if it is the fuel pump, but I can not find a picture online to where it is located and I cant find it looking under the hood myself. Also, would this be happening because its too cold and should I wait it out until it is above zero?
I am no mechanic by any means but would appreciate anyone's help/advice/anything. Once I took the jumper cables off the battery, it just clicks again when I try to start it. Thanks for reading and helping!
Old 06 Dec 2013, 06:36 pm
Default Re: Below Zero Temps and Unable to Start
Buy some starting fluid and give a shot in the air intake.
Your battery is low if starter only clicks.
talexander likes this.
Old 06 Dec 2013, 06:59 pm
Vlefaive's Avatar
New battery for sure, peace ( piece ? ) of mind will follow .
PS Nelson Mandela would have drove a PT , just sayin
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 06 Dec 2013, 07:03 pm
Handy_Cruiser's Avatar
Originally Posted by talexander View Post
Hi!......
Here's the schrader valve on the fuel rail under the black cap. But you need to try a fully charged battery first.
Old 06 Dec 2013, 07:08 pm
randyincctx's Avatar
Lightbulb Re: Below Zero Temps and Unable to Start
I am trying to locate the fuel line and the fuel gauge test port to see if it is the fuel pump, but I can not find a picture online to where it is located and I cant find it looking under the hood myself.!
The test port/Schrader valve for checking fuel pressure is located on the left end of the fuel rail.(Covered by black plastic cap in photo)
That could mean you still have a battery problem,in addition to fuel....Check the date on the battery,and have it load tesed to be sure of the CCA(cold cranking amps).
Aka:~KILLER~
Old 06 Dec 2013, 07:09 pm
Wink Re: Below Zero Temps and Unable to Start
Beat me by 5mins,while I was searching for the photo!lol
Aka:~KILLER~
Old 06 Dec 2013, 07:10 pm
Hi!
Handy and Randy, the last of the schrader valves were on the NA 2004 PTs. No PT after that time came OEM with a schrader valve. His is a 2006, so no schrader valve.
Jerry
rob342 and talexander like this.
Old 06 Dec 2013, 07:13 pm
Originally Posted by wwpptc View Post
Handy, the last of the schrader valves were on the NA 2004 PTs. No PT after that time came OEM with a schrader valve. His is a 2006, so no schrader valve.
Jerry
No schrader valve after 2004? What's the world coming to!
Old 06 Dec 2013, 07:40 pm
Thanks for your help, I tried that out but no go. I will be getting a battery tomorrow and try that. Thanks again!
Old 06 Dec 2013, 07:42 pm
Jerry
Awesome thanks so much! Found it, thanks again!
Tags
clicking noise, not starting
Bad misfire.. unable to fix FGTC General Turbo Discussions 3 01 Aug 2013 08:42 pm
Unable to locate flames decal Tereka General PT Cruiser Discussions 3 06 Sep 2012 11:29 am
At what temps does the fan come on? JenneK Tech & Performance Forum 13 10 Jul 2012 11:04 pm
Air box temps blucruzer Tech & Performance Forum 2 28 Apr 2009 11:33 am
P 2302 Fault Code unable to find Turbo Red General PT Cruiser Discussions 2 08 Feb 2004 12:37 am
