No break lights
Old 07 Dec 2013, 09:01 pm
Default No break lights
Have a 2004 cruiser and all 3 break lights dont work,replaced all the bulbs,break switch ,fuses are good ,and i have power to the break switch, all the other lights on the car work just not the break lights, any ideas
Old 07 Dec 2013, 10:11 pm
Default Re: No break lights
Did you break the brake bulbs?
Old 08 Dec 2013, 12:33 am
randyincctx's Avatar
Lightbulb Re: No break lights
Possible bad ground.......If voltage is present when the brake pedal is depressed,you need to check for a bad ground;Using a jumper wire connected to a good ground,probe the ground terminal at the tail light connector;If the brake lights come on,repair the ground circuit(Follow the ground wires from the tail light housing).
Aka:~KILLER~
Old 08 Dec 2013, 12:54 am
Hello, welcome to the forum. From what you have told us of your brake light problem, I suggest you check the C106 connector, a known electrical problem.
Look under the dash, behind the code reader plug, below the fuse block.
Find the large grey connector (next to a white one). It has a black lever lock to release and separate the halves. Look for heat damage, melting, etc.
Standard operating procedure-disconnect battery first.
These are related threads.
can't see the road!
Instrument cluster "no buss" fix
Old 08 Dec 2013, 12:49 pm
Ok i will check out that connector
Running lights/break lights leigh General PT Cruiser Discussions 2 25 Apr 2013 09:21 pm
How to break into my PTC? mr_ed Sound and Security Forum 7 13 Mar 2011 12:09 pm
Break Down CREWZIN Tech & Performance Forum 10 30 Jun 2005 10:09 am
Break in Thoughts Of Others, LAF General Turbo Discussions 3 16 Feb 2004 04:23 am
ok, Break it down for me. PTucker Stage Turbo Kits 10 28 Dec 2003 11:43 pm
