Wipers, Turn Signals And Head Lights Are Dead
Old 13 Dec 2013, 09:42 pm
Default Wipers, Turn Signals And Head Lights Are Dead
My wipers, turn signals and headlights are dead.
I checked the fuses and they are all good.
Anyone have any ideas what I should check next?
Thanks for any input.
PT Cruiser 2006, Automatic, Base model
Old 13 Dec 2013, 10:58 pm
Default Re: Wipers, Turn Signals And Head Lights Are Dead
Well after searching it seems that it is likely that it is one of the multifunction switches that has gone bad.
Can anyone here tell me how to test them?
Can anyone here explain why and how they are tied together?
Thanks again for any input.
Old 13 Dec 2013, 11:31 pm
soonercruiser's Avatar
Cool Re: Wipers, Turn Signals And Head Lights Are Dead
"Multi-function" switch????
Search the forum for threads on the subject.
Frank, aka SOONERCRUISER,
Old 13 Dec 2013, 11:32 pm
Sorry for bumping my own thread so much, but the more I read the more questions I got.
The question now is:
Is there a relay for the multifunction switches and if so does anyone know where I can find it on a 2006 PT Cruiser?
Thanks again.
Old 13 Dec 2013, 11:51 pm
Take off the housing or shroud on the steering column (2 phillips screws from underneath, then snaps apart).
On left is lights & turn signals, right is wipers.
Inspect the wiring....
Old 14 Dec 2013, 12:01 am
Thanks will do.
Old 14 Dec 2013, 10:48 am
I just noted you have a 2006 - that year they went to the CANBUS electric system where the computer controls way more than pre-2006.
Before you go crazy, I'd take off negative cable from battery (and clean it while you're at it), step on brake to drain residual charge (via brake light) then reconnect and see what you have.
It's like rebooting a PC. It may not work, but shouldn't hurt anything.
Old 14 Dec 2013, 03:35 pm
Thanks it's on my list of fixes.
Old 15 Dec 2013, 05:17 am
Bob; do Don's suggestion first. The 2006 and later went to a tipm. This module sends power to many components. It receives signals from switches, sensors etc. and then sends power to individual motors, lights,etc. The tipm is quite costly and complicated.
Your problem sounds like a wiring issue. It's doubtful that both MFS's went out at once. A high end code reader should tell you more. There are others on this site that know more about electronics.
Old 15 Dec 2013, 10:10 am
Thanks for the tip about a high end code reader. I did the key dance and got nothing.
However after fiddling around with the fuse and wires, it is now working again.
If it happens again I will have to narrow down exactly where this loose connection is.
2007 problem solved - No turn signals, no wipers, no highbeams, lights on Nameless1 Tech & Performance Forum 7 15 Aug 2013 07:36 pm
No headlights, turn signals, or wipers. Nathan Tech & Performance Forum 4 21 Dec 2012 02:37 pm
Fuse pops & wipers/ turn signals won't work... owensbigheart Tech & Performance Forum 1 11 Jun 2012 05:00 pm
Windshield wipers, turn signals, interior lighting ibking General PT Cruiser Discussions 0 09 Jun 2012 06:55 pm
No turn signals, wipers, washers for 2006 pt thundert79 General PT Cruiser Discussions 4 13 Dec 2008 09:55 pm
