Picture of clutch fluid reservoir cap ?
Like Tree3Likes
Old 18 Dec 2013, 09:03 pm
Smile Picture of clutch fluid reservoir cap ?
Does somebody have a picture (or can take one and post it here) of their clutch fluid reservoir cap?
Mine has had a plastic "thingie" ( I believe is called a diaphragm), and I just had my clutch replaced, and now, I can swear that the diaphragm is bigger than the one it used to have, but I would like to confirm.
If you can take one and post it here I would really appreciate it, below is the picture of my diaphragm semi-inside of the reservoir tank.
2003 PT Cruiser Turbo - ~96,000 Miles
Bought it in March 2010 with 49K miles.
DIY Work: Put in a K&N Cold Air Intake Kit the year I bought it. Brakes, upper and lower engine mounts (struts) replaced. Knock sensor replaced. Camshaft position sensor replaced.
Mechanic work: Replaced the timing belt at 90K miles. Replaced the engine at 95K miles (stripped spark plug hole, even the heli coil stripped after a week).
Old 18 Dec 2013, 09:24 pm
randyincctx's Avatar
Question Re: Picture of clutch fluid reservoir cap ?
Have you just been stalking the forum for the past 4+ years?lol......I think that may be illegal in California!j/k
Well,better late than never I say........Welcome to the forum!
BTW,my PT has an ATX so I can't help,other than posting a pic,but I will say that something doesn't look right in your photo?
Aka:~KILLER~
Old 18 Dec 2013, 09:42 pm
Default Re: Picture of clutch fluid reservoir cap ?
If that is indeed the original diaphram, you simply need to place two fingers on either side of it just below the top ring and push upward to pop it back into its original shape. Old style master cylinder diaphrams used to do this all time when the fluid got to low. We just popped them back up into their original shape.
That being said, the mechanic that replaced your clutch might have misplaced your original and used one off of something else, but I doubt it. On the bright side for you, you did get another problem thread posted into this site.
Jerry
Old 18 Dec 2013, 10:41 pm
Power Steering fluid will do this to brake parts.
Old 19 Dec 2013, 07:16 am
I had considered that as a possability but dismissed it when I noticed the LARGE formed protuberance that appears to be part of the bottom of the diaphram in the above posted line drawing. The part that looks like a prophylactic hanging down. It does take some imagination, but I can picture the top portion of the diaphram just popping back up into the cap like we did in the old days. This phenomenon may have occurred during the bleeding of the system as part of the clutch install process, as in they let the fluid get low enough to pull the diaphram down like our old master cylinders used to do.
Just flinging my stuff against the wall to see what sticks. Like I said above, this is just a possability and the op may indeed need a new diaphram.
Jerry
Old 19 Dec 2013, 07:19 am
double post
Jerry
Old 19 Dec 2013, 08:32 am
Jerry
I was looking at it ,and it looked like it was oversized? Like it's swelled up? Like happens when you mix the fluids.
I hope that other thing you mentioned don't do that!
Old 19 Dec 2013, 08:40 am
VNT's Avatar
VNT VNT is offline
That looks like it but as mentioned did the mechanic fill it with brake fluid?
I have taken that part the Rubber(no pun intended) out of the reservoir once a year and use turkey baster to remove the fluid and fill it with fresh bake fluid.
The top portion OD should match the OD of the reservoir and the cover should thread over it.
How much did they charge you to do the clutch?
Whos clutch did you use and did you buy a new flywheel since these things are modular?
Also did you have the slave cylinder replaced?
I ask because I have 3 stick GT's and at some point will have to change the clutches and not sure if I should go mopar or after market?
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 19 Dec 2013, 02:10 pm
I HAD CONSIDERED THAT AS A POSSABILITY, but dismissed it when I noticed the LARGE formed protuberance that appears to be part of the bottom of the diaphram in the above posted line drawing. The part that looks like a prophylactic hanging down. It does take some imagination, but I can picture the top portion of the diaphram just popping back up into the cap like we did in the old days. This phenomenon may have occurred during the bleeding of the system as part of the clutch install process, as in they let the fluid get low enough to pull the diaphram down like our old master cylinders used to do.
Jerry
Yep, as I said in the above post, I had considered the use of the wrong fluid as a possability. I've ran into that situation several times over the years. Unfortunantly the first time was with a Sunbeam Tiger that went through the shop around 1968. Those little buggers would move right along, even in stock form but you couldn't stop that one til we replaced the diaphram.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Jerry
Old 19 Dec 2013, 02:18 pm
Of course we'll never know if it was something simple or not until we get a reply from rasec after he goes out and checks into it. Hope he goes out soon before this simple little problem becomes a 20 page epic.
Jerry
Tags
diaphragm
P/S reservoir steves29 Tech & Performance Forum 11 29 Nov 2013 09:54 pm
Can't find replacement PS reservoir sawdust123 General Turbo Discussions 3 10 Oct 2012 08:17 pm
coolant reservoir question kruzin4now Tech & Performance Forum 2 13 Oct 2010 11:05 pm
01 Clutch oddity-possible clutch master cylinder? opelenvy Tech & Performance Forum 6 17 Sep 2008 03:35 pm
GT 5 speed clutch noise or " clutch chatter". boosta General Turbo Discussions 3 11 Aug 2003 08:10 pm
