Brakes pulsing/loss pressure
Old 26 Dec 2013, 04:08 pm
Default Brakes pulsing/loss pressure
Hello All,
2001 PT Cruiser
bought used 85,000
no brake problems until today.
First time stuck in bumper to bumper stop and go for an hour.
brakes starting pulsing and had to pump brake pedal to slow down.
ABS and TRAC OFF lights came on...
Let car rest for an hour, went back to driving everything fine for about 10 minutes and problem returned.
Did my rotors overheat or is it some other possibility....
brake fluid level good, no squeaking...
more of a whirring sound and brakes take some pumping to stop
please help thanks
Old 26 Dec 2013, 05:02 pm
Default Re: Brakes pulsing/loss pressure
Might have a small vacuum leak from the brake booster. Check all the hoses coming from the booster and follow them as far as you can and check for any signs of loose connections and splits in the hose.
Old 26 Dec 2013, 06:13 pm
Handy_Cruiser's Avatar
Check all vacuum connections first because that's easiest. Also check for fluid leaks, especially on the inside of each wheel and tire. And check the fluid level in the reservoir.
If there are no vacuum leaks and no loss of break fluid, then the next thing is the master cylinder. And in my experience, if the reservoir is full and you have to pump your breaks to stop, then the master cylinder is often the culprit.
I'm not familiar with the ABS on the PT, so someone else will have to let you know if there is anyway for the ABS itself to cause any symptoms like this. But I suspect ABS would likely not cause this.
Tags
brakes 2001
Loss of power steering, brakes & rough engine hotinhavasu Tech & Performance Forum 1 30 Nov 2013 01:55 am
Lights pulsing Strilla General PT Cruiser Discussions 4 09 Dec 2012 05:14 pm
Brakes "pulsing" after front pad replace and rotor turning Samson Tech & Performance Forum 8 28 Dec 2011 05:11 pm
Brake pedal pulsing UncLarryWasRight Wheels, Tires, Suspension 3 06 Jun 2008 06:12 am
Power loss Betsey General Turbo Discussions 5 10 Dec 2003 03:45 am
