15.5 gallons in a 15 gallon tank?
Old 27 Dec 2013, 12:55 am
Gru's Avatar
Gru Gru is offline
Default 15.5 gallons in a 15 gallon tank?
I was really low when I filled up my 05 GT recently. I was surprised to see I had put 15.5 gallons in when the auto shutoff hit. No gas spilled out, so I assume it didn't fill the filler neck and it was a pump at a station that I typically use.
How can that be? I am dealing with a 15 gallon tank, right?
In case I don't see you...
Good afternoon, Good evening, and Good night.
Old 27 Dec 2013, 01:43 am
Default Re: 15.5 gallons in a 15 gallon tank?
Why blame the pt?
Perhaps the gas station is ripping you off
Old 27 Dec 2013, 08:42 am
Busa may be right. They've caught a couple stations here in my county (after a few people complained) that something was amiss between what you paid for and what you received.
Old 27 Dec 2013, 10:39 am
When the last time anyone seen the weights and means people at a station? I used to see them. But has been years since I saw them.
Old 27 Dec 2013, 11:50 am
In CA weights and measures is done on a regular inspection bases. I often see new updated stickers on the pumps. It is also a misdemeanors and violators may be subject to civil or criminal charges.
These were taken 10 minutes ago at Safeway.
Finding Fuel station in the US cheating IMO is becoming a thing of the past?
As for the GRU getting 15.5 that would not be unuasal. For one thing the fuel tanks capacity holds more then 15 gallon on a level plane and if you "burb" the tank as you are filling it. Next the fuel system topped off to the filler next can hold about 16+ gallons.
Now please some of you eye lifters don't me get out the spare PT fuel tank and do precises CCing to get the exact amount to prove my response.
Old 27 Dec 2013, 12:25 pm
only thing i would question about 15.5 is why you would do that to your poor car. you ever change a fuel pump? it isn't too bad but it isn't exactly fun either.
this lady.. be happy you aren't this lady:
Originally Posted by photosbysusan View Post
I just bought gas and I thought the total amt of our pt gas tank was 15 gal. The gas station stated I got 16.79 gals. I am thinking the gas station is ripping everyone off and want to report them. Now I know it was pretty empty and I never let it normally let it get that low but.. I have never pumped that much gas in my PT Cruiser. I have a 2006.
Old 27 Dec 2013, 01:02 pm
Good find Rob. If I had to guess this is pretty close to what I estimate is the maximum fuel capacity under ideal pumping situations and maybe including the fill hose from the tank to the fuel cap?
The vent tube on the PT is very small and most fuel pump nozzles in the USA are highly pressure sensitive. So it takes some work to add more fuel in the tank when it is vapor pressured and even more so in the warmer seasons.
Old 27 Dec 2013, 01:12 pm
soonercruiser's Avatar
Cool Re: 15.5 gallons in a 15 gallon tank?
Every gas pump should have a state or federal inspection sticker that tells you the last date of inspection/calibration.
If something doesn't seem correct, you can anonymously call in a complaint.
Frank, aka SOONERCRUISER,
Old 27 Dec 2013, 01:14 pm
Or use someones name that you don't like..
Old 27 Dec 2013, 01:25 pm
UptownSport's Avatar
I know the Neon would hold more than tank's capacity- It was filling the filler tube.
I remember reading of a sophisticated scam; tests were done on 5 gallons- Someone noticed this and made programs to start cheating after 5 gallons!
Sophisticated and clever!
But overall I'd guess it was just as has been posted above, you can fill the system above stated capacity!
32.9 miles per gallon driving my GT!!! Gary04GT Turbo Performance 56 14 Jul 2013 02:18 am
Help!! 16 miles to the gallon pttb General PT Cruiser Discussions 10 10 Aug 2011 08:12 pm
miles per gallon ? premium gas partyd General Turbo Discussions 25 02 Jul 2010 02:25 pm
