P0302
Like Tree2Likes
  • 2 Post By Busa_Powered
Old 28 Dec 2013, 01:39 pm
Default P0302
anyone have a idea why my 02 pt cruiser only throws the p0302 code in the winter but no problems in the summer
Old 28 Dec 2013, 02:18 pm
Default Re: P0302
Huh, I take it you just got the code and if you did it might still be there when summer rolls around. Anyhow, if you do a search on that code you'll see that there's a few things to look at that would cause the code. Vacuum leak on the upper manifold, the gaskets between the upper and lower manifolds, bad spark plug or plug wire, fouled injector and last but not least it could be internal so a compression check of all cylinders to see if No#2 is different that the others.
Old 28 Dec 2013, 02:25 pm
Default Re: P0302
The code is for a mis-fire on cylinder two, it could be from a faulty spark plug or injector among other things.
Once you get above 2000 rpm the other 3 cylinders can cover the loss of power.
Check your MAF too
CREWZIN and Busted_PT like this.
Old 28 Dec 2013, 03:01 pm
Default Re: P0302
i bought the car last year in the winter it had p0302 code i changed everything coil plugs wires swaped injectors wouldnt go away summer rolls arround and it dissapeared winter came back and so did the code
Old 28 Dec 2013, 03:44 pm
Default Re: P0302
Gotta give it a good look over for a vacuum leak then. Heat expands so a tiny crack can be sealed whereas in the winter everything is colder. Did you check the oblong gaskets between the manifolds to make sure they weren't brittle and conform to the slots they fit in? Lastly, that compression check can rule out internal problems.
Old 28 Dec 2013, 04:22 pm
Default Re: P0302
As said above. Check the manifold really well on and around #2 cylinder.
P0302 Misfire Code From Hell! HELP! greenman285 Tech & Performance Forum 16 26 Sep 2014 11:12 pm
Misfire at Idle and P0302 code TurboJohn Turbo Performance 18 02 Jan 2014 09:34 pm
P0302 Cylinder 2 Misfire Detected Arclight52 Tech & Performance Forum 2 17 Jan 2013 06:46 pm
code P0302 mdfrodolives Tech & Performance Forum 12 12 Oct 2012 11:38 pm
P0302! PLEASE HELP! PtTurbo04 General Turbo Discussions 12 31 May 2012 10:17 pm
