Hood Latch Won't close
  • 1 Post By Handy_Cruiser
Old 02 Jan 2014, 10:45 am
Default Hood Latch Won't close
Hey guys, I'm here with another problem! I searched Google and the forums, couldn't find anything that was dead on relevant. I'm at work so no pics yet. Stay with me, I'll give you all relevant information so you guys can get an idea on whats going instead on me saying "it won't latch!" and expecting the correct answer.
Ok, I live in MI. Every day I travel from country roads (which I've discover the cruiser dislikes) to Lansing. If you're up-to-date with the weather, its been real fun with all the snow. This morning was 9 degrees F. Anyway, i ran out of washer fluid so I needed to pop the hood to refill it except the lever in the cabin wouldn't budge. My neighbor came over to help and his first attempt snapped the plastic in half. His second attempt actually popped the hood open, hooray!
He put wd-40 on the latch, refilled the washer fluid, and tried to shut the hood, its a no go. You guys probably know that the car has two hood latches. The first one is opened from the cabin. The second one is the lever in front on the car, where you put your hand into to open it. The second one latches, the first latch does not.
We popped the hood and thinking it may be frozen, took a hair-dryer to it. It still didn't shut. We played with the latch, it moves in the correct way (at least i think it does). But for some reason it won't close! On a hutch, my neighbor played with the cabin latch and none on the mechanisms inside the latch moved, so the cable might be broken as well. But the hood should shut, right? Even if the cable is broken?
I know this is long, but if anyone has any questions or need clarification, just ask.
As always, thanks in advance,
Josh
Old 02 Jan 2014, 10:59 am
Handy_Cruiser's Avatar
Default Re: Hood Latch Won't close
Watch this video:
While this video is about opening a stuck hood latch, it may also help you. If your latch is stuck in the close position (possibly due to a broken or frozen cable), this video shows how to get it into the open position.
randyincctx likes this.
Old 02 Jan 2014, 11:00 am
randyincctx's Avatar
Lightbulb Re: Hood Latch Won't close
You should be able to check the operation of the primary & secondary hood latch mechanisms @ the latch plate itself using a Phillips head screwdriver in place of the hood 'pin/catch'.....
Aka:~KILLER~
Old 02 Jan 2014, 11:17 am
Correct me if I'm wrong, but shouldn't the hood still close even if the the cable is frozen (it makes sense, but then again each car is different.). Also, does the release cable run underneath the car body? If so, there might be ice encased on it....
I know the secondary latch does work, its springy (at least as of yesterday). The primary one, I'm not sure. I go to lunch soon and I'll test it out. Thankfully my neighbor forgot a screwdriver yesterday and he left it in my car.
Old 02 Jan 2014, 12:18 pm
it runs through the firewall. If it is infact rusted/frozen, it may be stuck in the open position. Mine does this occasionally.
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 02 Jan 2014, 12:21 pm
Yeah, I just checked it. It indeed seems to be stuck in the open position. Which explains why it wouldn't "lock". The bottom spring seems slightly stretched but I can still poke it and bend it with a screwdriver.
Did you figure out a way to make it lock again, or is the answer going to be bungee cords?
Tags
hood, hood latch, latch
Rear Door Latch Help DJStorm Tech & Performance Forum 1 19 Jul 2013 07:37 pm
Hood/Bonnet latch. Marty_D General PT Cruiser Discussions 2 11 May 2013 01:18 pm
seat latch covers lalita Interior Accessories Forum 1 12 Aug 2010 07:31 pm
Chrome hood latch from cruiser motorsports rte662006 The Detail Shop 5 26 Mar 2008 10:37 pm
Painted Hood Latch CREWZIN Exterior Accessories Forum 15 05 May 2004 10:24 am
