CAM SENSOR and MAGNET
Like Tree2Likes
Old 04 Jan 2014, 12:10 pm
kctobyjoe's Avatar
Default CAM SENSOR and MAGNET
Another item I don't trust even tho no issues...
Bought the cam position sensor; an elliptical shaped gizmo; didn't realize there was a magnet inside also.
MY Q...Is this just a remove and replace item; unlike my '97 FORD TAURUS there are serious alignment issues to be concerned with when replacing; otherwise (FORD) SHE NO A START
EASY To get a; right by the car battery/air cage...
kctobyjoe
Old 04 Jan 2014, 12:59 pm
Default Re: CAM SENSOR and MAGNET
as far as I know, just remove and replace. no aligning necessary.
2016 Kia Soul Plus Black
Old 05 Jan 2014, 03:08 pm
Yup, just remove & replace . . . no big deal (rare huh?)
Old 05 Jan 2014, 03:29 pm
I would recommend making sure the part you remove is the same clocking position as the one you are replacing it with other then that it is a simple R&R part.
Last edited by NitroPT; 05 Jan 2014 at 05:51 pm. Reason: spelling and word addition that was missing?
Old 05 Jan 2014, 03:31 pm
Old 05 Jan 2014, 06:03 pm
MANY years ago I was the first to recommend replacing the magnet if replacing the sensor failed to cure the existing problem. It has been the correct fix several times since then. Of course there were other problems that ended up having a different cause and required further diagnosing.
If you noticed in the illustrations that CREWZIN posted, the back side of the is magnet keyed to the cam in several points. The guide pins are set up so the magnet will only fit ONE WAY. You can't install it wrong. I probably shouldn't say that, because someone will probably eventually force it in with a fine adjuster (hammer) and screw it up. Make sure to torque the magnet to 32 in-lbs (THATS INCH POUNDS).
Jerry
Old 05 Jan 2014, 06:41 pm
I keep on hand a couple of the CAMSHAFT POSITION SENSOR and TARGET MAGNET just in case someone has a problems when installing my cams. Although there are no moving parts they still seem to go bad for no apparent reason or condition that I am aware of.
New on the left old on the right. They are both genuine MOPAR.
Old 05 Jan 2014, 07:33 pm
kctobyjoe's Avatar
YAY...K !!!
Old 19 Aug 2016, 06:40 pm
Hi Guys.glad to be here and always happy to see your suggestions and repair ideas. I had this same problem with my 2003 PT Cruiser 2.4 ,wish i logged on to see this before i took it to the mechanic.Now it's a $140 job.it would have been easy to replace. You guys are great, Thanks.
rckstein likes this.
Old 04 Jul 2017, 09:06 pm
I wanted to give a great thank you to all of the admin and contributors to this forum. You have all made owning these vehicles a lot more bearable. My son and daughter each own their own GT Turbos. Recently my son's GT has been having a few issues and I believe I've narrowed it down to the cam sensor. I changed it and it ran great for about 15 minutes then went to limp mode. After researching this forum I've decided to order the magnet. Once it comes in I'll change that out and see if it solves his problem.
There have been other problems solved by the years of knowledge and expertise that I've discovered here. Thanks to everyone for sharing.
Road Magnet Springs? Remillard11 Wheels, Tires, Suspension 11 22 Mar 2012 06:48 pm
Free Cruiser Magnet turbomangt The Detail Shop 4 11 Dec 2004 09:57 am
PT Cruiser Magnet MOD Gary04GT The Detail Shop 6 10 Dec 2004 10:24 am
Scratch Magnet ! junkno General PT Cruiser Discussions 18 21 Sep 2004 01:16 am
