Size of bolt in the back of intake manifold??
Old 06 Jan 2014, 11:13 am
Default Size of bolt in the back of intake manifold??
2006 PT CRUISER TOURING 2.4L NA.
Recently I found there is a missing bolt in the back of the intake manifold,
like the pic bellow, thanks Alex_Clarke's picture.
I guess without this bolt ,the intake manifold is not hold firmly so it vibrate a lot.
Any one knows what that bolt is called, size and where I can get it?
Thank you.
Old 06 Jan 2014, 11:59 am
Default Re: Size of bolt in the back of intake manifold??
Hard to tell but it looks like a bolt that you circled? In the very early PT's there was an EGR pipe back there and it was held on by two different size bolts. In late 03 they did away with the EGR pipe and plugged the holes. You sure that "hole" your looking at goes all the way threw to something that would hold the upper manifold on? Most uppe rmanifolds are only held onto the throttle body by 3 bolts and 5 smaller bolts up front.
Old 06 Jan 2014, 05:34 pm
Thank you.
Actually, that bolt in the red circle is on something like a bracket, the bolt goes threw that bracket then into a hole on the side of the manifold.
Without that bolt, the manifold vibrate up and down a little bit when car idles.
Old 06 Jan 2014, 05:38 pm
What can I say about the second generation cruisers. Not sure why they would have that extra bolt there but nobody seems to be coming along to explain the situation or help you out. I still don't understand why the manifold would shake up and down at idle when the other bolts I listed held the manifold good and tight in the earlier cruisers. Oh well.
Old 06 Jan 2014, 06:11 pm
Anyway, Thank you.
I just think that bolt in the red circle will help a little.
It is not a big issue without it.
Old 06 Jan 2014, 07:49 pm
VNT's Avatar
VNT VNT is offline
I looked in the parts manual for the manifolds, it doesn't show that one, got a junkyard near you that allows you to go in, if so go visit and grab one.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 07 Jan 2014, 03:45 am
beauty; read the 2006 parts manual available on this site. It is in group 14; fig. 14-715. ---- I'd guess it is the one designated "M8 x 1.25 x 30 MM long with washer". ---- This manual is your friend!
Old 09 Jan 2014, 06:55 pm
UptownSport's Avatar
Would guess that's exactly what it is!!!!!
Power Steering Bolt Size! InfernoGT General Turbo Discussions 4 07 Jan 2014 02:48 pm
What size is this bolt??? hidinginparadise General Turbo Discussions 3 06 Mar 2011 07:59 pm
wtb 05-up upper intake manifold, throttle body, intake hose to turbo,aircleanor lid 1autodr Classifieds: Want To Buy 1 24 Feb 2011 05:15 pm
Control arm (BOLT) Size Bluecruiser Tech & Performance Forum 0 07 Sep 2010 02:33 pm
Back fire in intake manifold littleblueGT General Turbo Discussions 10 13 May 2007 09:42 am
