Drain the radiator without jacking the car?
Like Tree3Likes
Old 06 Jan 2014, 06:09 pm
Default Drain the radiator without jacking the car?
I checked the coolant in the radiator today, it is not very clean.
So I plan to drain and fill the radiator.
Is it possible do it without jacking up the car?
Thank you.
Old 06 Jan 2014, 06:39 pm
Default Re: Drain the radiator without jacking the car?
Not a lot of room under the PT but it could possibly be done. Do you know where the drain plug is? It's a rubber stopper that turns 1/4 turn to start letting the radiator drain, the plug doesn't come all the way out. Open the radiator cap to let air in as the coolant drains.
Big question is finding a container to capture the old anti-freeze so you can bottle it up and take it somewhere to dispose of it legally.
The picture below shows the back lower part of the radiator with the rubber plug near the bottom
Old 06 Jan 2014, 07:29 pm
VNT's Avatar
VNT VNT is offline
I would add, don't do it unless you can get the bleeder screw on the housing free first, that way you can bleed the system, spray some PB Blaster on the bleeder and carefully brake it free, then go to town changing the coolant, worse case jack the car up put a jackstand on the drive side.
Don't forget to use the correct coolant Hoat and distilled water.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 06 Jan 2014, 09:10 pm
Handy_Cruiser's Avatar
I just did mine Saturday.
The shallow container is the not the real issue. It's the drain cock. You have to twist and pull at the same time to get it to pull out far enough to drain the radiator. It's a really strange design. And if it hasn't been pulled out recently or lubricated in the past, it will likely be hard to get it to pull out far enough. And then it's got to go back in. The difficulty is the same there too. And of course, if you pull and/or twist too hard, it will break and may ruin the radiator.
It's not worth it. I recommend jacking the PT up far enough so you have room to see what you are doing.
Also, most of the new antifreezes are compatible with that old orange Duracool that the PT came with. My advice is to drain it all out, flush the system and put back in a good modern universal long life antifreeze. Once done, you can forget about needing special antifreeze. And many of the newer better quality universal antifreezes are approved by Chrysler for your car. Most older PT owners manuals were written before the new stuff existed.
Old 09 Jan 2014, 02:32 pm
Many Thanks.
I tried yesterday, It seems hard to get under the car.
I decide to get set of jack stands.
Is the
Craftsman 2-1/4 ton Floor Jack Set with 2-1/4 ton Jack Stands
safe enough to do the job when get under the Cruiser??
Thanks
Old 09 Jan 2014, 02:43 pm
Originally Posted by postbeauty View Post
Many Thanks.
Is the
Thanks
I know the PT seems BIG but........ya your Craftsman tools will work just fine.
Old 09 Jan 2014, 02:47 pm
I would get a pair of rhino ramps. then just drive up and you're good to go. but it's also good to get a jack and stands in case you have to remove the wheels.
NitroPT likes this.
2016 Kia Soul Plus Black
Old 09 Jan 2014, 05:46 pm
Yeah
Any one know the LIFTING positions where I can put the floor jack on and jack it up?
I check the manual, it just mentions the positions for jack stands.
Old 09 Jan 2014, 06:29 pm
Yeah
Behind each front wheel and in a little bit, there's a place where something bolts to the chassis with a nut sticking down. The cup on the jack fits nicely over that nut.
You can get the idea from this photo:
Old 09 Jan 2014, 06:35 pm
Todd
Floor jack in gravel and a tire for a jack stand...........= Hillbilly
radiator drain plug wood38 PT Cruiser Convertible Forum 2 18 Aug 2013 01:40 pm
Radiator drain plug bogaz Tech & Performance Forum 12 11 May 2012 01:54 pm
can't find radiator drain plug notarobot General PT Cruiser Discussions 1 28 Mar 2010 10:40 am
How to replace radiator drain plug? hotdog789 Turbo Performance 2 22 Feb 2010 11:57 pm
Radiator drain plug Mapper Tech & Performance Forum 16 15 Jul 2009 08:06 pm
