ABS and TCS lamps
  • 1 Post By Ray_Dockrey
Old 07 Jan 2014, 09:22 am
Question ABS and TCS lamps
Yesterday, the ABS and TCS lamps on my car went (and stayed) on. I did some searching in the forum, but had a different question. I have done the key trick, and I see "DONE", so the computer hasn't stored a code. Does that mean that if I bring it in to my mechanic,if he runs the diagnostic machine on it, that nothing will show? Or can something still be found by the diagnostics being run? Also, I saw in my manual that the TCS light usually illuminates whenever the ABS light comes on, so I am assuming that it is a problem with the ABS. Is it safe to keep driving with just the manual breaking system? I know some cars don't have Anti-lock breaks at all, so I was wondering. Money is tight and I'm not in the situation to have an expensive repair, so I wasn't sure how long I could let this wait before having it taking care of (diagnostics are being run tomorrow). Thanks so much!
Old 07 Jan 2014, 09:37 am
Default Re: ABS and TCS lamps
As long as you can't feel any thing different It's not a problem to drive that way. You will essentially have standard brakes. Push to hard they will lock up, like mine that don't have abs.
Old 02 Feb 2014, 12:44 pm
Cool Re: ABS and TCS lamps
I have the same problem. It's the pump unit most likely. There are two types one for all disk breaks and std rear breaks. The unit is only had from the dealer and cost $945.00, couch!! It's made in Germany. It's also not to easy to replace.
Old 02 Feb 2014, 01:36 pm
randyincctx's Avatar
Lightbulb Re: ABS and TCS lamps
What year PT Cruiser?.......Any recent work done?(like battery?or brakes??).......
One thing you might try first,is to initiate a 'reset',by disconnecting the negative battery cable,wait a few minutes,tap the brake pedal about 6 times,then re-connect the negative terminal,and see if the ABS & TCS lights come back.
Aka:~KILLER~
Old 02 Feb 2014, 01:51 pm
Ray_Dockrey's Avatar
Won't a bad wheel sensor cause those lights to come on? That is where I would start.
Old 02 Feb 2014, 01:58 pm
Correct - that's what is was with mine, a single bad sensor - not expensive.
Old 02 Feb 2014, 03:32 pm
I usually just let off the go pedal when that happens. Especially on snow.
Charliehorse
2010 Classic in Deepwater Blue w/Grey Interior
2008 Bullitt Mustang #901
Tags
abs, codes, tcs
Fog lamps interceptor General PT Cruiser Discussions 7 11 Jul 2012 11:50 am
Fog Lamps DragonCruizer Tech & Performance Forum 8 23 Aug 2011 09:24 am
Fog Lamps ... BHarrison Exterior Accessories Forum 1 27 Mar 2010 04:13 pm
Fog lamps PurplePTGirl General PT Cruiser Discussions 3 25 Feb 2008 09:50 am
Fog Lamps? thegoldpt General PT Cruiser Discussions 8 07 Nov 2005 02:22 am
