PT stalled won't crank
Old 12 Jan 2014, 06:42 pm
Default PT stalled won't crank
2005 pt turbo convertible stalled suddenly.. no sputtering, no warning lights. New battery
There is no clicking of solenoid, and i do not hear fuel pump. I have checked all connections, loosened and retightened all grounds. When i turn the key to start, there is no battery drain. I have checked fuses and swapped relays
I changed starter switch actuator but not switch. I was suspecting that, but then i noticed i didn't hear fuel pump either.
I want to test thin wire that i think should activate solenoid. It looks like a simple spade terminal, but I can't pull it off. There seems to be some sort of lock i can't figure out. Cant be that hard, but some help please.
I can't think of anything else. I am thinking and fearing pcm, but i really need some sort of diagnosis to go there. I am really on a budget.
Any constructive help would be appreciated.
Old 12 Jan 2014, 06:50 pm
randyincctx's Avatar
Post Re: PT stalled won't crank
If the 'ignition switch' is faulty,you won't hear the fuel pump.......
Aka:~KILLER~
Old 12 Jan 2014, 08:11 pm
Default Re: PT stalled won't crank
Turns out I changed the ignition actuator almost exactly a year ago.
I posted on this forum at that time before i solved, and i made reference to jumping posts 30 and 87 to get starter and solenoid to operate. Now, i can't remember what the heck i did. Can someone help me...where is post 30 and 87? And can someone help me get that wire off solenoid?
THx.. tomorrow i'll try to get the starter switch changed
Old 12 Jan 2014, 08:32 pm
Another thought. This is an automatic, but is there an equivalent to a 'neutral safety switch' that might cause this type of symptoms??
Car stalled, no coded VNT Tech & Performance Forum 2 02 Sep 2012 05:15 pm
01 stalled, no crank, no start - thoughts? darwal61 Tech & Performance Forum 7 06 Jan 2012 06:14 pm
car stalled mbp1128 General PT Cruiser Discussions 1 07 Oct 2009 11:29 am
Car stalled 3 days after work done R_I_PT Tech & Performance Forum 14 20 Jun 2008 02:41 pm
car nearly stalled.... Ptcruzer07 General PT Cruiser Discussions 13 06 Dec 2007 03:39 am
