Trying so hard to fix my PT. I had done it all before
  • 1 Post By needmoretoys
Old 14 Jan 2014, 12:59 am
Exclamation Trying so hard to fix my PT. I had done it all before
I've found fault codes, starter problems, etc and been able to repair it all by coming here or going on YouTube.
Well now I can't. I can't get a fault code, and here is what happened. Started car. Then, suddenly, before even getting out of park, it grinded down and stopped. Now it won't turn over. I had battery checked it's all fine. This wasn't the starter a minute ago because it did start fine but now it won't turn over. I considered alternator but it makes really scary grinding sound when I try to get it to turn over. Not bad bearing type either. I just can't figure it out and don't know no fault code is coming up. I have kids I take to school in this car a very little funds so need to try and fix this myself.
Help
Old 14 Jan 2014, 01:09 am
needmoretoys's Avatar
Default Re: Trying so hard to fix my PT. I had done it all before
check your oil. Look for metal in it. If it doesn't turn over at all it may have locked up. That would be worst case. where are you located? Maybe someone local could look at it.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 14 Jan 2014, 01:11 am
grinding noise when you try to start it sounds like a bad starter drive (gear on starter)
Old 14 Jan 2014, 02:11 am
It sounded like it was running, then grinding noise then shut off. That's what I got out of that. Sounds real bad to me.
Lenny
Old 14 Jan 2014, 08:15 am
cruserdad1976's Avatar
starter could have hung up engaged??? but id check the oil first
Old 14 Jan 2014, 11:21 pm
randyincctx's Avatar
Question Re: Trying so hard to fix my PT. I had done it all before
What's the milage?....You can't get it to turn over,or is it cranking but not starting?
Aka:~KILLER~
Tags
grinding noise, turn over
Down shifts hard bbromero Tech & Performance Forum 5 15 Mar 2013 04:46 pm
Hard Pipes PT_Panel Tech & Performance Forum 1 03 Nov 2011 09:55 pm
The Pt starts hard LNBNDN General PT Cruiser Discussions 1 03 Jun 2010 08:14 am
My PT downshifting hard! edj8 Tech & Performance Forum 24 19 Mar 2010 12:36 pm
Pulling hard to the right, Help! Victoria Wheels, Tires, Suspension 11 23 Jul 2006 10:20 am
