Traveling Radiator
Old 21 Jan 2014, 10:49 am
Default Traveling Radiator
So, in my journey to change out my water pump, I've gotten the car mostly back together save for a few things. Yesterday I tried to put the cross-member back over the radiator but was having issues because the radiator seems to have traveled over to the passenger side and maybe even a little higher than it was. I don't know how this is possible but judging by how it was lined up with cross-member. I have obviously jacked the engine up and down to get to the water pump but do you guys have any idea what caused it to travel and what I can do to get it back into position? Thanks in advance.
Old 21 Jan 2014, 12:00 pm
Default Re: Traveling Radiator
Assuming you are talking about the upper cross bar with the latch . You will need to check the lower mounting tabs on the radiator. Much like the upper except not slotted. Get the bottom in the top will lay down.
Tags
help please, radiator, water pump
Low Radiator Fan asallwey Tech & Performance Forum 6 19 Jan 2013 04:45 pm
Which radiator fan is best? 32seventeen Tech & Performance Forum 12 23 Jun 2012 10:09 am
PLEASE HELP! with my Radiator fan NIL8r General PT Cruiser Discussions 10 02 Apr 2010 06:58 am
