I stripped my thermostat housing!
  • 1 Post By OurPTGT
Old 22 Jan 2014, 02:02 am
Default I stripped my thermostat housing!
I seemed to have stripped my thermostat housing so my thermostat will not seal! I know that it's not a big deal and can be fixed relatively cheap. If I go with the helicoil route, what size will I need? And if I decide to drill it out and tap it for a bigger size bolt, what size would you recommend? I'm not against either option. I just don't know what size I need. Thanks in advance for ANY help I receive.
Old 22 Jan 2014, 04:03 am
Default Re: I stripped my thermostat housing!
I've never done a one legged puke. And I'm ok with that.
Old 22 Jan 2014, 08:03 pm
needmoretoys's Avatar
was it the front bolt? If so I put min in upsidedown and I thought it was stripped. One side is longer then the other. Also di you make sure the termostat was in right. There was a notch on mine that had to be put on only one way.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 22 Jan 2014, 09:05 pm
It was the back hole that is stripped. I never thought to compare the bolts. And the thermostat is in correctly. It doesn't have a notch, but the one I took out did.
Old 22 Jan 2014, 10:46 pm
Handy_Cruiser's Avatar
Try a longer bolt in the stripped hole. Chances are that there are still some good threads down in there.
Old 23 Jan 2014, 12:09 am
I'll give that a shot. I could always use washers if the bolt is too long.
Old 23 Jan 2014, 07:46 am
or run a longer bolt and put a nut on the other end
Handy_Cruiser likes this.
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 23 Jan 2014, 11:58 am
UptownSport's Avatar
The two 10mm wrench hex size?
M6 x 1.
That is a good idea to use a longer bolt.
Old 23 Jan 2014, 12:07 pm
M6 x 1.
Really what he should do is get one from you and replace it !
Tags
bolt, housing, leaking, stripped, thermostat
THERMOSTAT HOUSING IDNITITY???? Busted_PT Tech & Performance Forum 16 19 Jul 2013 03:55 pm
Thermostat housing problem SugarSana Tech & Performance Forum 7 09 Jan 2013 12:18 pm
Thermostat housing cowboyinboxers Tech & Performance Forum 11 20 Oct 2012 06:51 pm
01 leaking from Thermostat housing, Please help gdarst Tech & Performance Forum 11 06 Jan 2010 06:52 am
Thermostat housing replacement SRT8guy Tech & Performance Forum 5 12 Nov 2008 12:43 pm
