Transmission leak & have to keep putting fluid in
Old 22 Jan 2014, 11:13 am
Default Transmission leak & have to keep putting fluid in
Not sure where to start looking for where the leak is as I owned a Mercedes and have not worked on a PT Cruiser 2002. Guess there is a first time for everything. I want to help my landlord out by maybe fixing the problem. I have read on these cars and am just in shock at no space to work. Where would you start at looking for the leak? Thanks so much Mary
Old 22 Jan 2014, 11:28 am
Default Re: Transmission leak & have to keep putting fluid in
Axle seals, pan, lines, and also tcm (trans control module)
Old 23 Jan 2014, 05:51 am
Mary; assuming it is an automatic transmission car, and the leak is from the front of the trans, the clamps on the hoses at the front of the trans might need tightening. Trans pan gasket bolts might need tightening. The 3 vertical bolts on the solenoid pack [I think this is what Busted called the TCM] might need tightening.
Like Busted said, check the axle seals. Another likely candidate. Putting it up on ramps and checking with a light will tell you more. Wiping with a rag and running the car should help you find it.
Transmission fluid leak jcraft General PT Cruiser Discussions 5 18 Jan 2014 02:35 am
transmission fluid leak joeus Tech & Performance Forum 11 11 Jul 2013 09:18 am
Transmission fluid leak tryanmax Tech & Performance Forum 19 22 Jul 2012 02:16 pm
Transmission fluid leak! radio4mike General PT Cruiser Discussions 1 28 Jan 2012 07:12 pm
Transmission fluid leak!!! ptguy69 Tech & Performance Forum 0 20 Sep 2011 11:02 pm
