Pt 2006 front shields
  • 1 Post By randyincctx
Old 24 Jan 2014, 09:58 pm
Default Pt 2006 front shields
i need to identify these parts (cover/shield) as they are missing from my 06 limited edition turbo:
first one is the part located at the front/right side, it cover the water pump/engine mount from the wheel side (picture1)
the 2 one is the cover on the front/left side Inner Fender Splash Shield/cover
i need part number for both, and what kind of screws do i need to fix them..
also which is better : get new replacement parts, or used original part?
Thanks a lot
Old 25 Jan 2014, 01:54 am
Default Re: Pt 2006 front shields
Gram; What a nice clean motor/chassis you have there. The plastic shield is a large piece that is difficult to install. I'd recommend putting it on though. The info your looking for can be obtained in the parts manual available on this site. Be year specific [2006]. Not sure if the drivers side requires one?
Old 25 Jan 2014, 07:10 pm
randyincctx's Avatar
Lightbulb Re: Pt 2006 front shields
I believe these are the specific parts #'s for your 2006 PT Cruiser......And yes;part #1 is important...If you drive thru just the right water puddle,it can cause your alternator to possibly short/burn out.
Part #1- SHIELD. Left. Accessory Drive, Front Rail. EXPORT. CHRYSLER PT CRUISER (2003 - 2006) # 05027739AB, 05027739AA
2 Screws- SCREW. A/C Line Attaching, Chmsl, Deck Lid, Export, Ground Strap To Body, I/P Lower Left Reinforcement To I/P Side, Left, Line Mounting, Mounting, Reservoir & Pump Attaching, Reservoir To Bracket, Sensor Attach. Hex Flange Head Tapping, Hex Head. Lat
4 Bolts- BOLT, SCREW. A/C Lines Clip, Intake Manifold Attaching, Mounting, Sensor Attach. Hex Flange Head, Tapping Hex Flange Head. M6.3X1.81X20.00. Fits: CHRYSLER (1998-2013), DODGE (1998-2013), JEEP (2008-2013), PLYMOUTH (2000-2001), . # 06102152AA, 0610195
Part #2- SHIELD. Right. Wheelhouse. Front. CHRYSLER PT CRUISER (2006 - 2010) # 05152054AA
Also need- PANEL. Right. Wheelhouse. Fits: CHRYSLER (2001-2010), DODGE (2001-2010), JEEP (2009), . # 05027930AA
6 Bolt/Nut- NUT. Front Fender, Mounting. U Multi Thread. M4.2x1.41. Fits: CHRYSLER (2001-2011), DODGE (1999-2013), JEEP (2005-2010), . # 06507010AA, 06505635AA
4 Push Pins- PIN, PUSH PIN. Air Bag, Carpet Attaching, Deck Lid Latch Mtg, Left, Mounting, Right, Splash Shield. Retainer. Cross Member. 250X.900. Fits: CHRYSLER (1984-2013), DODGE (1984-2013), EAGLE (1988-1997), JEEP (1984-2013), PLYMOUTH (1984-2001), . # 060304
Not 100% sure of the quantities on some of the bolts/nuts/pins...Based most on the listed amount "Required" at the end of each part listing.
garkeller likes this.
Aka:~KILLER~
Old 25 Jan 2014, 08:04 pm
Here's some more helpful info:
Originally Posted by UptownSport View Post
Remove splash shield:
There's five fasteners. The three into the frame rail are 10mm wrench size, you'll need a socket and long extension to
access those three. The other two weren't there when we first removed. Also note engine mount bolt location.
Here's the shield removed:
Originally Posted by rice_killing_GT View Post
Remove the plastic shield protecting the bottom Torque Strut. There are (3) 10mm bolts holding it onto the frame, along with 3 push-in clips.
I broke one of the push-in clips, so becareful. After bolts and clips are remove pull out heat shield, you have to work it a little in the front for it to come out.
Pic of heatshield removed, with the lower torque strut exposed
Aka:~KILLER~
2006 Jack point Confirmation - front rvsailormm1 Wheels, Tires, Suspension 12 13 Dec 2013 02:14 am
2006 PT Touring front end bushings/links discovering06 Tech & Performance Forum 5 15 Feb 2011 11:25 am
Heat shields or none? PTCruisinTurbo General Turbo Discussions 12 04 Feb 2011 04:17 am
2006 Front Headrests PT Cruiser Touring outfit Classifieds: For Sale/Trade 2 01 Apr 2009 11:31 am
2006 Stock Front Bumper FT/FS CruiserKing Classifieds: For Sale/Trade 5 12 Aug 2007 04:09 pm
