Taillight Issue-Please Help
Like Tree4Likes
  • 1 Post By garkeller
  • 1 Post By CREWZIN
  • 1 Post By Motorhead
  • 1 Post By soonercruiser
Old 25 Jan 2014, 11:05 am
Unhappy Taillight Issue-Please Help
I bought a 2007 Yellow Pastel Cruiser in August. In December, the left taillight went out. I replaced the slightly-cracked bulb. One week later the new bulb was cracked much worse. I replaced it and the next bulb lasted four weeks. When I called the gas station where I bought the bulbs, they lectured me about handling the bulb with my bare hand. So, I went to a chain car repair shop and they replaced the bulb last Friday. Today, 1/25, my bulb was not working again. Please provide any advice you have because I really want to keep my Lemon Drop!
Old 25 Jan 2014, 11:21 am
garkeller's Avatar
Default Re: Taillight Issue-Please Help
---my first thought would be bad gasket allowing rain/liquid into the bulb area, especially with the cracked bulb as a clue... I'll now step back for the experienced techs on here to give the issue a "crack"
LemonDrop likes this.
Old 25 Jan 2014, 11:54 am
Welcome to the forum.
As was said above, is the gasket around where the bulb fitment sits into the light in good shape, not cracked or missing that would let moisture inside the light?
If that's ok, check all around the outside of the light for any cracks around the lens where it meets the grey plastic part of the inside.
Next, check inside the socket hole where the bulb goes to see if there's any rust stains. Should be clean and shiny. Also check the wiring as far as you can to see there's no cracks in the wiring cover that would allow the wire to touch bare metal.
Old 25 Jan 2014, 12:37 pm
Just went through this.
My right brake/marker bulb was out. I thought is was odd that both filaments were dead.
Upon changing the bulb, I was surprised in seeing the old bulb glass broke in two. All the seals and the socket seem fine, so I replaced, and will see how long this one lasts..................very odd.
A while ago the signal on the same side was dead. It needed a new socket (dealer only, $15).
As far as lecturing you about handling, that applies to halogens (headlight/fog), not incandescent .
A still runnin' 01 Limited,,all with a little prayer, and a lotta elbow grease
Red tint tails, chrome trimmed grille, custom towel rack buttonless flamed shifter, auto dimming rear view, Homelink remote transmitter, driver seat drawer, MOPAR sub, lowered 1" rear, MOPAR/Borla dual tipped exhaust, chrome trimmed GT gauge/airbag surround, front 35% tint, and the ever so important Fuzzy Dice
Old 25 Jan 2014, 09:09 pm
soonercruiser's Avatar
Cool Re: Taillight Issue-Please Help
THIS ^^^^
Usually incandescent bulbs are not a problem with a little finger grease.
Does that ever seem to be a problem with your household light bulbs???
No!
(BTW - not touching with your hands does apply to your headlight bulbs too.)
But, it's a good idea to just wash the hands clean before doing it anyway.
(Especially if you have torn the dash apart to get to the small bulbs, like I'm about to do.)
Frank, aka SOONERCRUISER,
Old 25 Jan 2014, 09:28 pm
Thank you for everyone's thoughts. I do have moisture in my tailLAMP, including in the light bulb area. I am going to do a electronic diagnostic check on Feb. 3 to see if that is the issue. I do not want to replace the entire lamp and gasket but I think that is the best solution.
Old 26 Jan 2014, 07:49 am
I had a small crack in the turn signal part of the lens. Very hard to see. I super glued the crack, which worked for a while, but eventually replaced the light.
Tags
taillights, wiring
3in1 Taillight? Jtwheels2007 Exterior Accessories Forum 1 15 Dec 2012 01:16 pm
taillight query keymon3891 General PT Cruiser Discussions 1 14 Feb 2009 10:15 pm
Right rear taillight gonzomania Classifieds: Want To Buy 2 10 Mar 2007 12:47 pm
Need a RR stock taillight for an 04 GT Jmanning843 Classifieds: For Sale/Trade 1 09 Jun 2004 06:44 pm
Yet another new PT taillight Stephen R. Exterior Accessories Forum 9 02 Apr 2004 06:45 pm
