Right Headlight Issues
Like Tree3Likes
  • 1 Post By CREWZIN
  • 2 Post By sanatanadharma
Old 27 Jan 2014, 07:06 pm
Default Right Headlight Issues
Hi, my '03 Cruiser's right headlight went out. I replaced the bulb but it still does not work. I checked the fuse and it looks fine, although I will swap it out anyway later on just in case (hard to be motivated to work outside in these temps). In the meantime, is there anything else I can check before assuming it's an issue with the wiring? Thanks
Old 27 Jan 2014, 07:35 pm
Default Re: Right Headlight Issues
Might be just the bulb holder. Have you checked voltage at the socket?
garkeller likes this.
Old 27 Jan 2014, 07:37 pm
In the fuse block by your knee, fuse #19 controls the right low-beam circuit (fuse #20 is for left). Also check fuse #1 (25 amp) though it would affect both left and right.
In the under-hood PDC, the 15 amp fuse # 16 (17) controls both high-beams.
Busted_PT and garkeller like this.
Old 27 Jan 2014, 08:11 pm
garkeller's Avatar
Yep, Crewzin said what i always check first, if power is at the socket at all, then reverse trace the problem...fuses, relays, then unfortunately in my case with my wife's Nova, a r-a-t decided to nibble at her headlight wiring and that was the issue for me
Headlight help bhunt41 Exterior Accessories Forum 8 17 Feb 2011 04:11 pm
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
HEADLIGHT ISSUES mikey10143 Canada PT Forum 10 10 Oct 2007 02:29 am
Headlight ty97206 Exterior Accessories Forum 1 24 Sep 2007 02:18 pm
Headlight Issues jmack General PT Cruiser Discussions 9 18 Feb 2005 06:23 pm
