error code p 0340
Old 04 Feb 2014, 01:36 pm
Default error code p 0340
My engine light recently came on and my car stalled out on the side of the road while I was driving it. I since have been able to start it (only several hours later though). It will run for a short period of time and then die out again. The error code I received was P 0340 which is the Camshaft Position (CMP) Sensor Circuit. I saw that this part is only about $40-$50 online. Is this a difficult fix? and what are the chances that it is not the CMP and I still have this issue after replacing it? Any help is appreciated. Thanks!
Old 04 Feb 2014, 01:39 pm
Default Re: error code p 0340
BTW I have a manual 2007 PT Cruiser Pacific hwy edition if that helps..I just changed the spark plugs and wires before I knew it was the CMP
Tags
cmp, engine light, error code, p0340
Error Code 0340, changed Cam Sensor, still won't start dave44602 Tech & Performance Forum 19 28 Nov 2014 02:53 pm
code 0340 leslie381 Tech & Performance Forum 2 19 May 2012 07:56 pm
Error code P0456 & 0340 RoadTramp113 Tech & Performance Forum 12 21 Feb 2011 08:29 pm
Error code 0340 Callygirl Tech & Performance Forum 6 22 Nov 2009 10:30 am
Error Code 0340 KingKole02 Tech & Performance Forum 16 02 Oct 2008 04:05 pm
