Hello,
I own a 2002 Cruizer base model with 180,000 miles. The tranny gave out on me when it had 120,000 so I had it rebuilt. Now recently I started to notice a shudder or a small jolt when slowing down at around 25 MPH. Its more noticeable when making a hard stop but I can also feel the shudder (though very faint) when making a proper stop. Other than shifting down to first gear all other shifting is smooth. I have not changed the transmission oil since the rebuild at 120,000 miles. I am wondering should I do a transmission flush? Or has anyone else ran into the same issue? Also no check engine light, yet. Thank you for your input. ![]() V/r |
![]() Quote:
I'd do a chemical detergent transmission fluid flush http://www.amsoil.com/shop/by-produc...mission-flush/ , new filter and chemical synthetic ATF. Here's some reading: http://www.amsoil.com/search.aspx?searchedtext=shudder
i have the same issue, they told me the same thing but didnt get chance to replace the motor mounts.. plz keep us updated if you get yours fixed.
Thank you. |
Chrysler recommends that you don't add anything other than ATF+4 to their transmissions. [except for dye for testing for leaks].
the issue is the transmission solenoid block. thanks for the suggestions
Today i decided to buy a brand new Mopar solenoid and i replaced mine,
it didn't fix the problem!!!!, after few minutes of driving it happened again! this thing is driving me crazy.., if anyone can advice plz. 06 turbo, auto. Thanks in advance. |
Downshifting while braking. I have a 2009 that I bought new and it's done the same thing you're describing since day one.
Here again with the same issue.....
I replaced the solenoid but didn't solve the problem, after few days my problem get worse than before, the engine light come out with 3 codes Then I replaced the output sensor and changed the trans oil and filter. All problems fixed and no more shudder for 4 weeks. Few days ago the problem is back again!!!! What's wrong with this car? Any suggestion please? |
Tags |
asap, flush, pt cruiser 2002, tranmssion, tranny |
Thread Tools | |
Display Modes | |
Transmission stuck in 1st gear 2007 PT Cruiser Touring (Automatic transmission) | ProdigyMan | Tech & Performance Forum | 7 | 19 Jan 2014 02:51 pm |
Automatic Transmission Pan Bolts.... | a_bartle | Tech & Performance Forum | 13 | 01 Mar 2013 06:35 pm |
Automatic Transmission | 01limited94 | Tech & Performance Forum | 5 | 01 Feb 2013 10:09 pm |
Automatic Transmission | ptcruisersam | General PT Cruiser Discussions | 7 | 08 Feb 2012 06:43 am |
using second gear with automatic transmission? | gfx | Tech & Performance Forum | 2 | 18 Jul 2004 02:24 pm |
