Rattling Shock
Old 09 Feb 2014, 08:05 pm
ejstith's Avatar
Default Rattling Shock
I put new shocks on the back of my PT. After awhile there was a hell of a rattle back there. I took the shock off and the rattle was gone. I took that shock back & got another one and the rattle stopped. Now the same rattle is on the other side. Is there a torque value to tighten the shock bolts? I thought I had downloaded the PT shop manual or had bought it on a CD or something but I can't find it anywhere .... I tightened them about as tight as I can get them without putting an impact gun to it ... Thanks ...
2005 PT, Limited turbo Lite. Automatic all whistles and bells.
Old 09 Feb 2014, 08:10 pm
randyincctx's Avatar
Post Re: Rattling Shock
Torque specs for the rear shocks are: Upper Mounting Bolts = 73 ft/lbs & Lower Mounting Bolts = 65 ft/lbs(2002-up) 50 ft/lbs(2001 models ONLY!).
Aka:~KILLER~
Old 09 Feb 2014, 10:39 pm
ejstith's Avatar
Default Re: Rattling Shock
Thanks a ton Randy.....
Old 09 Feb 2014, 11:10 pm
What shocks were they?
The securing bolt on this type of tube dampener mainly only prevents the loop bushing from sliding off the shock (dampener)stud on the top. On the lower end it at least needs to be snug enough not to allow movement of the lower tube in its mounting area and then properly torqued. If you are hearing strange sounds or the suspension action is very different in a uneasy manor you should carefully examine all other points of the rear suspension. If you raised the car and lowered the axle as you should have during installation you have moved your rear suspension in ways that it has not done in years. So chances are other things may be of concern that you unknowingly uncovered?
I recommend anti- seize on the studs and thread unless they are polyurethane bushings in which no petroleum products should be used for lubrication.
Old 11 Feb 2014, 02:06 pm
ejstith's Avatar
Thanks Nitro. They are Gabriel shocks. I just put the hardware back on there that came off of it. I took the shock off & drove it around & no rattle at all. I didn't torque the bolt, just tightened it. I will though since I know the torque value. Thanks again....
Old 14 Feb 2014, 05:40 am
ej; I too had noise problems with the gabriel shocks. Noisy within 6 months and one of them leaked within a year.
The torque numbers from Randy are for dry threads. Drop 10 % for oiled threads.
Old 14 Feb 2014, 08:56 pm
ejstith's Avatar
Thanks PT06......
Rear rattling/ clunking Jayson_Dread Turbo Wheels/Suspension/Handling 13 22 Mar 2013 01:18 pm
Passenger side rattling LooseJox Tech & Performance Forum 2 14 Jun 2012 09:38 pm
Rear end rattling Rymanrph Sound and Security Forum 11 13 Jan 2006 01:43 pm
Rattling rear! xyster Sound and Security Forum 5 15 Sep 2005 11:57 pm
Rattling sound while speeding up. amazingarthur General Turbo Discussions 4 23 Sep 2004 03:03 am
