overheating
Old 14 Feb 2014, 02:07 pm
Default overheating
i have a 2007 pt cruser and i have replaced the radiador,thormostst,.i know its not waterplump.but i drove it for two weeks no prosble and lastnight my husband drove it and it overheated.he put a whole bottle od antifrezze in it and when he got home it was doing it again.i am reaady to kill this car.please someone help.
Old 14 Feb 2014, 03:00 pm
Default Re: overheating
have you considered the cooling fan? it's been highly documented for this problem. and, if the system is not completely burped so that air is out, it will overheat as well.
2016 Kia Soul Plus Black
Old 14 Feb 2014, 04:28 pm
midnite72's Avatar
Send a message via AIM to midnite72 Send a message via MSN to midnite72 Send a message via Yahoo to midnite72 Send a message via Skype™ to midnite72
Could of damaged the engine.
You don't poor antifreeze or water in an overheated vehicle.
Are you running the heater when you drive??
I run my defroster at all times..
Vroom, Vroom, BABY!
Old 14 Feb 2014, 04:47 pm
Lots of reasons why a car overheats. We have no idea how the car was maintained. Was the correct cooling fluid used, if not it could have an adverse affect on the fluid that was already in the system. If you don't have the Turbo, you have two speeds on your radiator fan and like soyomb just said, one speed could have burnt out. Very common problem. Is there any leak at all where your loosing/dripping antifreeze on the ground. Any loss of fluid would cause air to get into the system which would cause the overheating, or are you loosing fluid and not seeing anything on the ground. That could be a sign of internal (head gasket) problems.
Welcome to the forum.
Old 14 Feb 2014, 07:42 pm
How is it overheating?
By that I mean is it overheating anytime or only when the car is sitting or stuck in traffic?
The cooling fan is known to fail a lot. So that may be the problem.
Overheating PT parkerjohn Tech & Performance Forum 5 05 Feb 2015 02:01 am
Still Overheating? JSRocket Tech & Performance Forum 9 13 Aug 2011 01:33 pm
Help overheating!!! Kblevins Tech & Performance Forum 15 10 Aug 2011 02:45 pm
Overheating PT GT Fuct General Turbo Discussions 4 04 Aug 2011 04:46 pm
Still Overheating Cruz2success Tech & Performance Forum 2 19 Jul 2011 10:43 pm
