RKEM replacement advice
Old 16 Feb 2014, 01:26 pm
Default RKEM replacement advice
We recently purchased an 02 PT limited for my wife with 75k on. Super crazy clean but only came with one remote and key.
After a month the remote stopped working but the interior lock switches and headlight, fog lights, etc all work fine.
Changed batteries in remote to no avail. The original batteries tested good anyway.
I read about 100 threads on the subject.
No clicking noise from the RKEM area.
#10 underhood fuse, #3 and #10 underdash fuses all good. I even swapped with known quanity fuses from another PT we own.
Tried reprogramming the remote but it never gives me the "entering programming" chime.
I even tried programming a remote from our other PT just to see if it would work. Again, never enters programing mode.
So, are there any other DIY tests before I order an RKEM??
Also, I see alot of people replacing these with Salvage units for $40-$50 but considering the failure rate, I was thinking of spending the money and buying a new one for less than $100.
Opinions?
Also, does a NEW RKEM come with remotes??
Thanks, David
Old 16 Feb 2014, 02:00 pm
randyincctx's Avatar
Post Re: RKEM replacement advice
Supposedly the Chrysler/Mopar 'Keyless Entry System, MODULE PACKAGE-#82207153' comes with the module & 2 remotes
(should come pre- programmed to match RKE? IDK):
Keyless Entry System, MODULE PACKAGE. Factory keyless Entry. Fits: CHRYSLER (2001-2013), DODGE (2001-2013), JEEP (2001-2013), PLYMOUTH (2001), . # 82207153
Mopar 82207153 Keyless Entry System Part Keyless Entry Kit | eBay
Aka:~KILLER~
Old 16 Feb 2014, 02:11 pm
Default Re: RKEM replacement advice
You actually have an advantage.....Since you own another PT,you can transfer/swap the RKE from one PT,to the other,and see if the problem moves with it.
RKE ID# isn't stored into the PCM memory like SKIM codes are,but the RKE is still accessable through DRB-III for programming when no remotes are available,and new a one is needed.
Aka:~KILLER~
Old 16 Feb 2014, 02:22 pm
Check also these fuses, as they will interrupt power to the RKEM.
PDC fuse # 18 (20 amp)
Dash FB #13 (10 amp)
muffler replacement need advice Carzboyz General PT Cruiser Discussions 10 31 Aug 2013 04:34 pm
RKEM HELP KTBoom2006 General PT Cruiser Discussions 8 24 Jul 2012 06:59 pm
Need some advice-Problems with my replacement engine Abgmauldin Tech & Performance Forum 11 16 Feb 2009 09:14 pm
Any advice for my first oil change or replacement of spark plugs? TheFox General PT Cruiser Discussions 3 14 Sep 2008 11:24 am
RKEM Bdog Tech & Performance Forum 4 13 May 2008 08:32 pm
