2006 PT Tail lights not working
Old 17 Feb 2014, 07:56 pm
Unhappy 2006 PT Tail lights not working
I have a 2006 PT and the tail lights stopped working yesterday. I have brake lights and all running, headlights and dash lights, just not tail lights and license plate light. I checked the lights and plugs for corrosion. Both were clean. I tested the plugs, I get nothing with the lights on, but when the brakes are pushed I have power to the plug. I'm lost, I really don't want to chase wires everywhere, so if someone has had the same issue, any help will be appreciated.
Old 17 Feb 2014, 11:05 pm
InfernoGT's Avatar
Default Re: 2006 PT Tail lights not working
Sounds like a blown fuse to me. I couldn't tell you which fuse number it is but I believe there is a diagram on the fuse cover to point you in the right direction.
2006 PTGT with 5spd. ~60k miles
Old 18 Feb 2014, 02:57 am
jgl; power comes from the TIPM on one wire and splits and goes to each taillight and the license plate lamp. There are connectors along the way. Since you have brake lights, the taillight ground is good; as stop and tail use the same ground wire.
Old 18 Feb 2014, 09:49 am
All the fuses are good, pulled them when I found the lights were still good.
Old 18 Feb 2014, 10:17 am
On an 06 with the CAN-BUS system, They only thing I can recommend is to pull the negative battery cable for 5 minutes for a computer reset. Can't hurt.
Old 19 Feb 2014, 06:08 am
Crewzin; I forgot about that one. Good call.
2005 PT Dream Cruiser - Brake and Tail Lights Stopped Working ArkansasTraveler General PT Cruiser Discussions 5 10 Aug 2015 07:42 pm
Head Lights and Tail lights not working. 1morgana General PT Cruiser Discussions 6 15 Nov 2014 12:38 am
Tail lights not working Rockinkiwi Tech & Performance Forum 3 12 Nov 2012 01:15 pm
2008 Tail Lights not working, please help! PeteyNelson Tech & Performance Forum 2 07 Jun 2011 01:19 pm
Tail Lights Not Working Sue General PT Cruiser Discussions 6 27 May 2011 11:00 am
