Heads up, tranny pan w/drain $14 @ Amazon
Like Tree4Likes
Old 18 Feb 2014, 04:43 pm
Default Heads up, tranny pan w/drain $14 @ Amazon
Listed as "Used, good condition" but I'd bet it's just a returned one. As a matter of fact, I did lay down my bet and one is one the way... LOL.
Amazon.com: Buying Choices: Dorman 265-801 Transmission Oil Pan
Anyway, thought someone might need one and is as cheap as me.
Handy_Cruiser likes this.
Old 18 Feb 2014, 06:34 pm
Handy_Cruiser's Avatar
Default Re: Heads up, tranny pan w/drain $14 @ Amazon
That's a great deal for someone that needs one.
Old 18 Feb 2014, 07:35 pm
buy 2 they work better then one!
Busted_PT likes this.
Old 19 Feb 2014, 03:19 pm
LOL..... I almost did at that price. But then I couldn't afford the extra gallon of ATF+4.....
Old 20 Feb 2014, 01:45 am
Here is what I did with 2 of these inexpensive pans!
rob342 likes this.
Old 20 Feb 2014, 10:26 am
LOL, I know.... and it held about an extra gallon, right? I could afford the pan(s) and I have a welder.... I just couldn't afford $36 for another gallon of ATF+4 (Since it would actually cost more to fill it than making a double pan itself would.) It was my lame attempt at a joke, LOL.
BTW, what was with the keystock welded to the bottom..... skids just in case there was contact? I wasn't sure of the purpose?
Old 20 Feb 2014, 10:33 am
The extra capacity pan goes along with the extra fluid lines to the very large fluid cooler.
The key stock was added as a joke because of a comment from a friend I won't mention his name (Danny). The pan itself is so solid that if you did bottom the suspension it would protect the transmission from damage. The funny thing is that the key stock added does effectively cool the pan. We found this out when the welding was being done. The main body was getting very hot even around the key stock but the key stock remained noticeably cooler! Go figure?
Old 20 Feb 2014, 10:51 am
"Thermal mass". It will keep it cooler for a while but once it's reached it's soak limit it will also take longer to cool off.
You should have welded the bars on the inside... it would be "stealth" then....
Old 20 Feb 2014, 12:15 pm
The only stealth on the PT is what the Dyno says. That my friend as on most of my vehicles is for my information only!
Heat soak Accounted for that and that is why there is a thermostat by-pass!
I am very careful about controlling the fluid temperatures in an automatic transmission. My sweet spot is 160-180F easily done with a little thought about what to use.
Some suggested the tubes in the pan like the old TransDapt trans pans. LOL
Really the key stock was just intended for looks. IMO looking gooood!
Old 20 Feb 2014, 12:33 pm
oh yeah? that's nothin.. check out what IIII did with fourrrr of these inexpensive pans!
NitroPT likes this.
$170 for fulls set of shocks/struts KYB-GR2s amazon.com ptcruiser94 Wheels, Tires, Suspension 19 08 Mar 2014 06:08 pm
My Amazon TYC 2298 PT Cruiser Radiator.. Warning: Lots of Opinion & Pics, Little Data scoleman69 Tech & Performance Forum 5 18 Dec 2013 04:26 pm
Power flush vs. drain/fill for tranny. sgraves Tech & Performance Forum 4 01 Jul 2013 01:49 pm
front window shade from Amazon, which? gychang Interior Accessories Forum 1 26 Aug 2010 10:43 am
