Door lock LH side, power
Old 20 Feb 2014, 05:30 pm
Default Door lock LH side, power
Lock buzzes and hesitates to unlock when activating power unlock. I am uncertain which part is worn and needs replacing. I pulled door panel and verified the noise coming from the doorlatch. Any suggestions?
Old 20 Feb 2014, 08:22 pm
randyincctx's Avatar
Post Re: Door lock LH side, power
The drivers side door latch & locking mechanism are one unit,and will need to be replaced as such;If you want to verify that it is bad,you can check it with a multimeter......But,assuming (do to lack of info) whatever year your PT Cruiser is (2001-2010?),it has probably gone thru enough cycles to warrant a replacement reguardless.
Aka:~KILLER~
Drivers Side Door Lock no longer working Judhudson Interior Accessories Forum 13 07 Sep 2013 06:00 pm
Driver's Side Front Door Doesn't Power Lock dmcondolora Sound and Security Forum 3 03 Aug 2013 09:23 pm
Driver Side Door Lock Problem mstyler05 Tech & Performance Forum 2 20 Dec 2010 10:10 pm
power door lock kits? mamabear Interior Accessories Forum 4 31 Jan 2009 11:34 am
Driver side door lock problem KTBoom2006 General PT Cruiser Discussions 5 13 Oct 2006 08:19 am
