towing ?
Old 20 Feb 2014, 10:12 pm
Default towing ?
I have a 2001 limited edition and I need to know if I can safely tow a 14 foot fishing boat? it is a small 14 foot kennedy craft boat with a 20 hp motor .any feedback will be appreciated
Old 21 Feb 2014, 06:29 am
Crid's Avatar
Default Re: towing ?
U will be able to pull that with no problem. I have both a 2013 see doo and that trailer that weight bout a 1000 lbs. and also a utility trailer that I have pulled more than the rated max with no problem. I hope this helps. Someone else will chime in. Hope this helps
Corey
2006 Cruiser, Non-Turbo, 19 inch Konig Trouble rims on 225/35/19 Ironman Imove tires, Airaid CAI, E3 Plugs, msd super conductor 8.5 mm wires, Freedon Design Strut Tower Brace, Glow Shift Pillar gauges, EBC Slotted Rotors with EBC Green Stuff Ceramic Fiber Core Pads, Lowerd on Tien springs, Full Custom Kenwood Excelon sound system with 1 12" JL Audio W0, 8000k Blue hids up top and aftermarket OEM Fogs with white 8000k in bumper. Ipcw Bermuda black true led taillights with tinted reverse lights.
Old 21 Feb 2014, 08:53 am
Snapper, you didn't say what your boat and trailer weigh. According to the owners manual, with a Class A hitch, you can safely tow 1,000 lbs.
Old 21 Feb 2014, 12:09 pm
thanks for the responses . my boat, motor and trailer weigh less than a thousand pounds. I have never seen a pt pulling a trailer and wanted to make sure it was safe before I spent the money on a hitch.
Old 21 Feb 2014, 01:03 pm
cruserdad1976's Avatar
there is a gospel group i knwo that pulls a closed trailer and a lot of equipment it may not weight as much as a big boat or a travel trailer but there PT does a good job and its a NA auto
Towing dafichter General PT Cruiser Discussions 19 08 Nov 2015 11:29 am
towing behind a RV suzieq General Turbo Discussions 11 20 Jan 2014 04:10 pm
Towing eye? BladeRunner General PT Cruiser Discussions 6 10 Dec 2010 07:38 pm
Towing shodobe Tech & Performance Forum 2 20 Jul 2005 12:04 am
towing rrrperry General PT Cruiser Discussions 4 02 Apr 2004 02:03 pm
