►No start when outside temp is below zero
Old 21 Feb 2014, 10:48 am
Default ►No start when outside temp is below zero
When the outside temp is below zero my 2004 Cruiser fails to start. (48,000 miles)
When trying to start I can hear the engine try to start but any further attempts only clicking sounds are heard. I'm guessing the sound is the starter solinoid.
The battery was replaced 9 times since 2007.
Should the solinoid, the starter, or both be replaced?
Old 21 Feb 2014, 11:05 am
Default Re: ►No start when outside temp is below zero
Why was the battery replaced so many times AND why wouldn't you think the battery needs replacing again this time? The symptoms seem to point at the battery. What are the CCA (Cold Crank Amps) of the battery your using? Might have to step up to a higher level.
Old 21 Feb 2014, 05:52 pm
The batteries were replaced because they failed. The last time it failed to start hearing a clicking sound, it was taken to my mechanic, he put it inside where it was a little warmer and it started successfully. I then took the car to Auto Zone and had the battery tested. The instrument said the battery checked ok and the cranking amp were correct. The current battery, installed Dec 2013 is the largest physical size battery (MT26R) Interstate makes that will fit. Auto Zone has a similar battery but I haven't tried that yet. When the outside temperature is below zero (the cruiser is parked in a carport.) the car will not crank,even with a good battery. The car was checked thoroughly by an automotive electrical shop where my #7 battery was installed on 12-10-2012. The Interstate dealer replaced the battery under warranty with #8 on 10-29-2013. The dealer replaced it again with #9 on 12-09-13 but told me the Interstate sales rep would not replace #8. so he change to a different manufacturer.
The alternator tested is delivering full amps.
I would measure the battery current drain when the car is off to check for leakage but I cannot find the drain in milliamps with the car off.
The cruiser was new in August 2004 and with only 48,000 miles most of my driving is local but the battery should still fully charge within a couple of miles.
Sorry to ramble but I hope it helps.
With a good fully charged battery why does the starter solinoid only make a clicking sound when the outside temperature is below zero?
The car is located in Northern Michigan and this is the worst and coldest winter in many years.
Thanks,
Don
Old 21 Feb 2014, 05:59 pm
Thanks,
Don
Have you replaced the battery cables and terminals lately? Are all the ground locations clean and not corroded? Checked the ground straps to the engine? Just a thought...
Charliehorse
2010 Classic in Deepwater Blue w/Grey Interior
2008 Bullitt Mustang #901
Old 21 Feb 2014, 10:39 pm
this is more likely the issue......your negative to ground might be loose at one point, either to the batt terminal or at the engine block.
Old 21 Feb 2014, 11:33 pm
Who leaves the house when it's 0* ?
Old 21 Feb 2014, 11:55 pm
Coyote; When the power goes out and your bathroom is 2 below zero.
Old 22 Feb 2014, 12:00 am
garkeller's Avatar
That's one Throne I wouldn't want to be King of!!!
2002 Chrysler PT Cruiser Base (2.4/automatic)
2000 Chevrolet Blazer LT 4dr SUV 4WD
1998 Ford Mustang Sport (3.8/automatic)
1974 Jeep DJ-5C (4.2/automatic/LH drive)
1973 Chevrolet Nova Sedan 350 (automatic)
Old 22 Feb 2014, 09:47 am
Good suggestion CDYNACO, I will have my repair shop check the cables and ground cable and for corroded connections. Remember though the only time the solinoid clicks is when the outside temp is below zero. All other times there is no clicking sounds and the car starts normally.
Old 22 Feb 2014, 11:58 am
I hate it when that happens!
9 batteries in 6 years is a huge red flag that something is wrong. cdynaco's advice is sound, check all the cable and ground connections to make sure that they are clean and tight. If you don't find the problem there you might have it checked for a slow draw on the battery (ie; short or security system malfunction) although I would hope that your mechanic would have checked for that after the second or third battery needed replaced.
Good luck.
car temp goes hi wen AC on? notime0075 Tech & Performance Forum 6 08 Aug 2013 05:14 pm
▀█► PT Cruiser AC Big Problem ken2028 Tech & Performance Forum 11 07 Jul 2013 09:46 pm
▀█► A/C expansion valve location? 2006 PT Cruiser Touring Edition ken2028 Tech & Performance Forum 2 07 Jul 2013 03:55 pm
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
oil temp brngrhd General Turbo Discussions 0 17 Mar 2004 12:53 am
