p2074 terrible idle fluctuating rpms
Old 27 Feb 2014, 05:21 pm
Default p2074 terrible idle fluctuating rpms
Hey everybody, this is my first post as I am a new member. I've been having problems at idle. Pulled fault code p2074. Car will fluctuate idle between 1000-1500 rpms, with steady throttle it will fluctuate about 50rpm up or down. Exhaust sounds terrible. Its a 2009 n/a automatic with about 90k miles. Since I got that code I've replaced the map, tested the tps, cleaned the throttle body and tested (only with throttle cleaner) for vacuum leaks. Everything I can see is fine. I am really confused on this one, any suggestions are much appreciated
Old 27 Feb 2014, 05:25 pm
Default Re: p2074 terrible idle fluctuating rpms
Also I do have a video of these problems in action, it's on YouTube but I don't know how to add a link. It's titled p2074 idle problems pt cruiser.
Old 01 Mar 2014, 12:13 am
Dave; I'd start by replacing the PCV valve. Check for any vacuum leaks. Check the wiring to the TPS and the map sensor.
cold idle =~ 1200 rpm
hot idle =~ 750 rpm
Flickering lights and fluctuating gauges needles... sugarpike Tech & Performance Forum 21 19 Sep 2016 03:47 pm
No idle and codes P2074 and P0508 Cat22 Tech & Performance Forum 2 19 Oct 2011 05:57 pm
Fluctuating idle after cleaning/changing IAC 2004 GT HO. neocrusier Tech & Performance Forum 0 21 Dec 2010 06:43 pm
Engine surging at 4000 RPMs along with shaking at 2000 RPMs... brian5060 Tech & Performance Forum 3 24 Jul 2010 07:42 pm
2005 Turbo Rough Idle Suddenly MPG Terrible MimisMom Tech & Performance Forum 6 04 Aug 2009 06:13 pm
