adding fog lights right now need help!!!
Old 02 Mar 2014, 01:43 am
maverick's Avatar
Default adding fog lights right now need help!!!
I have everything intalled properly wires connected ,multifunction switch attached. try to turnthem on and they do nothing . I checked the fuses and they are ok and in right places,I even disconnected the battery to reset car. is there something I am missing here. I am in garage and doing this at this very moment . need help asap!!
Old 02 Mar 2014, 02:20 am
randyincctx's Avatar
Question Re: adding fog lights right now need help!!!
Did you install the new relay in the PDC?
Aka:~KILLER~
Old 02 Mar 2014, 02:26 am
maverick's Avatar
Default Re: adding fog lights right now need help!!!
relay in pdc? clueless as to what the pdc is and the relay lol . so thats a no
Old 02 Mar 2014, 02:50 am
Post Re: adding fog lights right now need help!!!
My bad;I actually meant the fuse in the PDC located in the engine compartment,behind the air box.....Check the cover on the PDC,and it should say FOG (20A).
The fog lights are controlled by the same relay as the headlights,which are all controlled by the MFS.
The MFS & the #8 fuse break the circuit between the battery and the fog lights (when the high beam are activated,the headlight relay cuts the power to the fog lights)......The headlight relay is located below the interior fuses,in the blank spot by thumb on the right side (5-Pin/DPDT relay) which is absent in this particular photo(the left side is reserved for heated seat relay).
(Photo courtesy of santanadharma)[/COLOR][/B]
Aka:~KILLER~
Old 02 Mar 2014, 03:01 am
maverick's Avatar
the top picture in the engine compartment I added. the headlight relay is in there stock correct? the interior one
Old 02 Mar 2014, 03:03 am
maverick's Avatar
theres a fog light fuse in the interior fuse compartment also says non bux
Old 02 Mar 2014, 03:12 am
Does your PT Cruiser have a black plastic box in the engine compartment,like the one I posted a photo of?(near the positive jumpstart point)
If it does,then there is another FOG fuse located inside of it,the guide on the top of the black cover should look similar to this photo(notice how it shows 'FOG (BUX) 20A' @ #22):
Is there a 20A fuse in that slot?
Aka:~KILLER~
Old 02 Mar 2014, 03:21 am
maverick's Avatar
yea and I placed a good fuse in it that I borrowed from another slot as I dont have any spares lol and still didnt work.
Old 02 Mar 2014, 03:26 am
Have you tried the fogs while switching between high & low beam headlights?........Fogs won't work if highbeams are on,the relay cuts power feed to the fogs.
Aka:~KILLER~
Old 02 Mar 2014, 03:33 am
maverick's Avatar
ya I tried them on both . I am pretty confused at this point as to why there not working. seems like I have done everything directed
Adding a turbo Westminister General PT Cruiser Discussions 4 02 Feb 2014 09:32 pm
Info on adding rear fog lights BMotter Exterior Accessories Forum 13 20 Oct 2013 06:51 am
Adding Cruise Control and Fog Lights VNT Tech & Performance Forum 2 17 Apr 2011 03:49 pm
Adding Foglights to my '03? mikelikestobike Exterior Accessories Forum 12 17 Dec 2010 07:38 pm
ADDING A SECOND HORN rszappa1 General PT Cruiser Discussions 15 08 Sep 2010 01:56 pm
