Identify the item
Like Tree3Likes
  • 3 Post By wwpptc
Old 02 Mar 2014, 06:07 am
Default Identify the item
Good day for all! I'm sorry about noob question, but after rats incursion i need to find missing parts. TIS didn't help.
That is this part and connection from them?
Old 02 Mar 2014, 08:06 am
Default Re: Identify the item
That's your Cruise Control Servo. That front connection goes over the top of the engine to the throttle control wheel. The back connection is a vacuum line which goes behind the engine to a "T" junction with other vacuum lines.
Old 02 Mar 2014, 09:04 am
Additional question to Sir Crewzin.....If I'm not mistaken, TS pic was an 03-below model.....do you know w/c one of the 2 ports is the low side for AC recharge?TIA
Old 02 Mar 2014, 09:25 am
The picture should answer your question. Picture is from the 2001 - 2003 Haynes Repair Manual.
Old 02 Mar 2014, 03:11 pm
Before this a/c charge point question starts to go on and on as other posts about it have done in the past, let me say this, "it's impossable to do it wrong". The freon can has a hose that has a fitting on the end that will fit onto the correct side of the system ONLY. All factory a/c systems have two differant size fittings. The aftermarket freon fill cannister will NOT connect to the wrong side of the system. You CAN NOT do it wrong.
[IMG][/IMG]
Jerry
Old 02 Mar 2014, 05:59 pm
Thanks for answering my question Crewzin & wwpptc!!!
Old 02 Mar 2014, 09:44 pm
randyincctx's Avatar
Lightbulb Re: Identify the item
Get an 'A/C Pro' kit....I used one on my Ford Ranger almost 2 years ago,and it's still working great!(A/C Pro also contains a leak sealer)
Aka:~KILLER~
Old 02 Mar 2014, 10:06 pm
Thanks, Randy! will check that one in Advance Auto.
Whats this item and where does it go?! bluebossa Tech & Performance Forum 12 10 Oct 2013 08:03 am
identify this.. gramicci Wheels, Tires, Suspension 5 08 Jul 2013 07:07 am
Identify these? chris15 Wheels, Tires, Suspension 4 27 Aug 2009 10:17 pm
New item turbomangt The Detail Shop 7 24 Oct 2004 03:11 pm
New item turbomangt Vendors & Buyers Forum 0 01 Jan 1970 12:00 am
