Running Rough now wont start
Old 02 Mar 2014, 10:39 am
Unhappy Running Rough now wont start
i have been having issues with my PT running, while driving it would stall out sometimes or seem like it was starving for gas and my odometer would act like a tack. I replaced the Intake air temp sensor, still same issues.
Then yesterday after driving around running errands before i was heading to a show. It ran rough, i was able to get it home ( slowly ) hooked up my code and it read
p2302
p0113
02 sensor
So i disconnected the battery and let it sit till my Bro in law came over. I hooked it back up, tried to start it , ran for a few seconds then stopped. It would not start back up, nothing , no click or anything when i turned the key.I have power from the battery.
any ideas? could it be the starter or ???
Old 02 Mar 2014, 10:54 am
Default Re: Running Rough now wont start
a few other things:
2005 basic
i'm at 122,000
replaced my timing belt ,water pump around 80,000 (?)
last tune up 50,000
change oil every 6000 +/- with Synthetic
Old 02 Mar 2014, 05:33 pm
Still no luck,
Changed Plugs, wires,
had battery tested and starter both are good....
stumped...
calling tow truck in AM
hopefully it's simple fix
all fuses/relays are good as well
Old 03 Mar 2014, 03:15 am
paisano; P-0113 = intake air temperature sensor. ---- Check the wires for breaks or the connectors for corrosion.
rough running, backfire bsides45 Tech & Performance Forum 10 27 Feb 2013 05:17 pm
Running rough, sometimes... primostoy General PT Cruiser Discussions 10 16 Jul 2012 03:52 pm
Rough running '06 GT CruzinGT General Turbo Discussions 14 21 Nov 2010 08:45 pm
car stopped running and wont start..... ptismakingmemad Tech & Performance Forum 10 03 May 2010 02:33 pm
01 PT Running Rough lucky594 Tech & Performance Forum 5 17 Aug 2007 11:22 am
