high-pitched whine from engine
Old 04 Mar 2014, 08:53 pm
Default high-pitched whine from engine
Hi folks! I have an '01 PT with almost 200K on it. Two months ago I noticed a strange noise coming from my engine compartment. I had recently replaced the water pump (the timing belt was replaced too) and thought the squeakity squeakity sound I was hearing might be a bad replacement pump. The squeak transitioned to a loud, high-pitched, constant whine. The whine sounds very similar to alternator whine you may hear coming through an amped car sound system. Like that whine, this sound increases in pitch as rpm increases. After tinkering around a bit, I isolated the noise to either the tensioner pulley, a/c, or power steering pump as the noise disappeared when that belt was removed.
Today I replaced the tensioner pulley. Whine is still there. I also noticed that the engine looked wet on that side. I checked the PS reservoir and it was very low so I added fluid to it. Unfortunately, the whine didn't go away. Would everyone agree that the PS pump is the culprit?
Thanks everyone!
Old 04 Mar 2014, 09:04 pm
Default Re: high-pitched whine from engine
Thanks everyone!
What dose turning the wheel do to the noise?
Old 04 Mar 2014, 10:59 pm
Turning the wheel does nothing noticeable with the noise. It is there at idle (although not as loud) and gets louder and higher pitched as rpm increases. Also, turning on the A/c does not have an impact either.
Old 05 Mar 2014, 09:28 am
In my opinion you just ruled out those as the culprit. With the pt running Spray wd or other on the belt to see if that changes any thing. This is temporary but will rule in or out the belt itself.
Old 05 Mar 2014, 12:48 pm
I'll try spraying some WD on the belt. What made me even think to check around pump was that I thought the sound sounded familiar. I remembered that I had heard a similar noise coming from the car when I would turn a sharp turn during the cold months while the engine was still cold. The high pitched buzz would stick with me for miles before fading away. Turns out the reservoir was low. I added fluid and the noise stopped immediately.
I'll post back once i spray on the WD. It would be nice if a simple belt switch did the trick!!
Old 05 Mar 2014, 12:55 pm
Handy_Cruiser's Avatar
It very well could be the front alternator bearing. One or two others on this website have had their 2001 alternator start whining and so have I. Changing alternators is the solution to that one.
It could also be the tensioner pulley. If it is the AC pulley bearing, the tone will likely change when the AC is turned on. Also, my 2001 belt tensioner is weak and even with a new Gates belt, it still chirps if driving in a rainstorm. I've got a new tensioner but haven't installed it yet. WD40 should make a noise from a weak tensioner change.
Old 05 Mar 2014, 01:36 pm
Thanks for the info. I thought of the alternator too, but the culprit is tied to the belt that turns the a/c, tensioner pulley, or PS pump as when I removed that belt the noise disappeared completely.
The tensioner was replaced yesterday and the buzzing whine is still there, so that knocks it out.
I can put my ear right up to the a/c and the noise def. seems to be coming from higher up in the compartment. Also, I listened using a stethoscope on the a/c and it sounded very smooth.
I thought the PS pump b/c it is in the area where the noise is coming from plus there was a lot of fluid coming down across the engine from that area. Could the pump pulley bearings be going out?
Also, something that just popped into my head...the leaking fluid had dripped onto the belt. Wouldn't that provide lubrication as mentioned in the WD post? I cleaned the belt and it had no impact on the noise.
Old 05 Mar 2014, 01:47 pm
And Stethoscope on PS pump sounds like????
Old 05 Mar 2014, 02:23 pm
I couldn't get the thing in there to listed to it. It wasn't long enough to go up from the bottom. I'll have to see if my dad's thinner hands and arms can go down from the top.
Old 05 Mar 2014, 07:01 pm
Vlefaive's Avatar
For what it's worth, any high pitched whines in my case usually come from the passenger seat .
In which case I just drop her at either the mall or her mother's
malisa likes this.
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
High pitched whine from radio RacerX Tech & Performance Forum 3 14 May 2011 08:51 am
very loud high pitched noise Triplecat2002 General Turbo Discussions 6 30 Nov 2009 08:53 am
high pitched whine triggerman Sound and Security Forum 7 12 Sep 2006 04:37 pm
High pitched whistle at WOT rice_killing_GT Turbo Performance 9 28 Nov 2003 08:39 pm
High Pitched Squeak SFsGT03 Turbo Wheels/Suspension/Handling 2 08 Nov 2003 06:37 pm
