removing satelite reciever
Like Tree2Likes
Old 16 Mar 2014, 12:29 pm
ptprice's Avatar
Default removing satelite reciever
As I've never used the satelite radio feature or ever will, I'd like to remove the satilite radio reciever on the rear of the roof. I can do the cosmetic hole repair once it's removed. I just want to know what is envolved in removing it and will removing this interfer with my on board built in PT Cruiser navation system? And, would removing this reciever interfer witlh normal AM FM function on my radio? thanks, ptprice
Old 16 Mar 2014, 12:57 pm
Default Re: removing satelite reciever
I would say there is no dependence because I have an '05 also, without Satellite radio, and I have AM/FM and the compass by the sunroof works.
I would think you want to remove headliner to see how to remove the "shark fin".
Old 16 Mar 2014, 01:03 pm
Are you trying to go off the grid?
Old 16 Mar 2014, 03:21 pm
Here is the hole in the top. It's about 1 inch square. You pull the two rear grab handles and the two push in plugs in the rear of the head liner, to get at the wire.
You may just want to color it to the car. I primed with adhesion promoter and high fill primer and painted to match.
Old 16 Mar 2014, 03:27 pm
ptprice's Avatar
My radio does have the Chrysler navigator system built into it. It's based on the CD that came with the car in 2005. You put the CD in the player slot in the radio and thru a series of steps the onboard navigator function comes up. My concern is that this navigation part of the radio might become nonfunctional w/o the "shark's fin". The navigation feature supplied by Chrysler with the CD is based on roads existing in 2005. My apartment complex wasn't constructed in 2005 so every trip I make using this on board navigator shows on the radio screen as begining in a Florida swamp till I get out to Sterthaus Drive! It's still good for major roads and destinations though. The world hasn't changed that much. My PT, "So Big", also has the temp,compass overhead consule that I'm sure are independent of the "sharks fin. Thanks for your feed back, ptprice
Old 16 Mar 2014, 03:34 pm
I would say yes it does go with the navigation.
Old 16 Mar 2014, 03:50 pm
ptprice's Avatar
Thanks Busted. From your info I now I know how to take the fin out. I just have to get info now on if the "sharks fin" services my on board radio CD navigator. Figgering this out will be one of my first projects after the big "C" surgery on my left kidney this week. It'll keep my mind occupied till I can do the work. Thanks, ptprice
Old 16 Mar 2014, 04:05 pm
Wish I had more info just to make sure your truly disrated. Will pray for your speedy and full recovery. With your permission that is.
Old 16 Mar 2014, 04:48 pm
ptprice's Avatar
Well, I'm gonna look at that $@#^&*() "shark fin" this way, if its necessary, I'll leave it on to keep the onboard navigator working. The premise being function overrides appearance. Thanks for the good info and good thoughts. ptprice
Old 16 Mar 2014, 06:07 pm
They really look good body color. Just leave the rubber black. Otherwise It looks like someone was to lazy to mask it off.
Removing Exhaust Cat JaviPTGT Turbo Performance 5 04 Aug 2008 08:53 pm
removing emblems bobby ray Exterior Accessories Forum 2 10 Feb 2006 12:02 pm
Removing Wax From Bumpers BenWaB3 The Detail Shop 23 10 Apr 2004 08:35 pm
removing cat kruzzinpt Turbo Performance 3 06 Aug 2003 10:00 pm
Removing air filter box Craig Tech & Performance Forum 2 22 Nov 2001 12:34 am
