annunciator bell
Old 17 Mar 2014, 12:27 pm
Default annunciator bell
Hey all,
I have a 2010 PT...recently, it seems when I am taking more than a gentle turn (like I'm pulling into a driveway), occasionally the annunciator bell dings...nothing shows up on the dash. The first time I heard it, I thought I was low on gas and I expected to see the low fuel light on when I looked down but there was no light lit (and I had plenty of gas).
Any ideas?
Thanks,
Tim
Old 17 Mar 2014, 12:34 pm
Default Re: annunciator bell
That bell rings if you have your turn signal on for a particular length of time to remind you that you haven't made a turn and might have left the turn signal on. Maybe you put your indicator on a long time.
Old 17 Mar 2014, 02:40 pm
cruserdad1976's Avatar
crezwin is this on all PTs ??? I have never heard it in mine but then what are these signals you are talking about????????
Old 17 Mar 2014, 02:49 pm
Check your brake fluid level.
Jerry
Old 17 Mar 2014, 02:53 pm
cruserdad,
On mine (maybe Chrysler deleted it later), if you put your turn signal on, make a slight turn that wouldn't take the turn signal off, after about 15-20 seconds, a chime/bell starts going off in the dash to let you know the turn signal is still on.
Old 17 Mar 2014, 03:22 pm
I'll pay more attention to the directionals when I use them and see if that's what is causing it. I'll also check my brake fluid...Standard DOT 3?
Old 17 Mar 2014, 03:33 pm
According to my repair manual, yes, Dot Type 3
Old 17 Mar 2014, 03:48 pm
Excellent...thanks. I need to pick up a shop manual for my PT...the suspension is
getting hammered with these brutal frost heaves...the worst I've seen in over 50 years of living here in NH.
Old 17 Mar 2014, 03:59 pm
the pot holes are getting bad and I mean REALLY bad in Misouri
Old 17 Mar 2014, 04:09 pm
2step's Avatar
There are a number of things that will cause the chime to sound off. The first one that comes to my mind is the low fuel warning chime. It dings once when you have about 3 gallons left to go and it dings 3 or more times when you have about a gallon left. There are other 'warnings' for brakes, traction control, etc, etc. Usually they also light up a icon or message in the dash but it's possible some don't.
Kenne Bell supercharger wwpptc Tech & Performance Forum 4 23 Jun 2012 06:28 am
Bell crank bf4cm28 Wheels, Tires, Suspension 3 22 Mar 2009 05:07 pm
Kenne Bell Optimizer II dcorreia1 Tech & Performance Forum 7 17 Mar 2003 02:22 pm
Kenne Bell supercharger semar Tech & Performance Forum 0 09 Dec 2002 11:58 pm
Kenne Bell MNShaleCruiser Tech & Performance Forum 2 24 Jan 2002 03:31 pm
