Engine swap
Like Tree3Likes
  • 1 Post By InfernoGT
  • 1 Post By UptownSport
  • 1 Post By Busted_PT
Old 20 Mar 2014, 12:31 pm
bubba_1952's Avatar
Default Engine swap
I have a friend with an 2004 GT and the motor died. He has put an N/A 2.4 standard motor in it but it will not run. Can anyone tell me what all has to be done to make this motor work for him. I appreciate any advice/help to pass on to him before he goes any further spending money.
bubba_1952
Old 20 Mar 2014, 01:39 pm
InfernoGT's Avatar
Default Re: Engine swap
bubba_1952
I'm going to reach in the haystack for a needle of an answer and say: Use the PCM that came with the 2.4 NA and vin-match it to his car?
boonie2 likes this.
2006 PTGT with 5spd. ~60k miles
Old 20 Mar 2014, 03:09 pm
Different wiring harness. That's not going to work. What model motor is it? 03 and up first and the compression is too much on a n/a for the turbo cars . He needs a turbo motor. Just what exactly happened to the original motor?
Old 20 Mar 2014, 04:25 pm
cruserdad1976's Avatar
That has to be the FIRST time any body ever asked How to put a NA in a Turbo ( yes i know he didnt actually ask but its the same thing)
From what i have read he needs a major mircle along with a bunch of the parts off the NA
Old 20 Mar 2014, 07:00 pm
InfernoGT's Avatar
Wait, is he keeping it turbo or going to a NA setup?
Old 20 Mar 2014, 07:20 pm
Was the motor at least an '04 motor?
Old 20 Mar 2014, 09:48 pm
UptownSport's Avatar
PCM has no idea what kind of engine it's running- N/A or Turbo.
Only thing that matters is that it's an '03 & up.
Old 21 Mar 2014, 12:00 pm
bubba_1952's Avatar
Hi guys, The 2004 turbo motor died and he decided he would put another engine in it from his other Cruiser that was wrecked. The other cruiser I believe was and 02-03 model Limited PT. He has removed the turbo set up and is using a regular ecm in place of the turbo ecm. A whirlwind of problems for sure.
bubba_1952
Old 21 Mar 2014, 12:26 pm
Can't use the other ecm. Can't use 01 or 02. Unless he accentually turns the turbo car into the other car. Wiring harness and all. As it is. He has to use the turbo pcm. Motor must be 03 or newer.
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
engine oil pan swap cruizinla Tech & Performance Forum 2 13 Oct 2009 07:32 am
engine swap nimblemotors Tech & Performance Forum 10 01 Aug 2009 02:09 am
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
engine swap INFERNODPPT Tech & Performance Forum 21 29 Oct 2005 10:00 pm
