p0706
Old 21 Mar 2014, 08:16 pm
Default p0706
Seem to be having random starting problems lately. My scanner picks up a p0706 but no cel light comes on. Sometimes The gear indicator on dash has square boxes around the gears. So that tells me that the range sensor may be having a issue or bad. Car has not started twice and today it finally started after having battery unhooked for 30 mins.
Is this sensor hard to replace? I know the valve body must be removed to access it. is a 2007 Touring. Thanks
07' touring Totaled April 2014
Old 23 Mar 2014, 07:14 pm
Default Re: p0706
Seems to be doing it more often. Using my scanner and clearing it seems to allow starting. Guess it's off to the dealer.
Old 28 Mar 2014, 09:02 pm
Default Re: p0706
Seems like the problem was fixed. Cleaned the computer connections, and replaced the transmission ground wire since I messed it up while cleaning it. Has been starting fine for the last 4 days.
Old 28 Mar 2014, 09:17 pm
Default Re: p0706
