MFS Plastic connector issue
Old 24 Mar 2014, 09:37 am
Unhappy MFS Plastic connector issue
Have 01 PT Limited bought new, usually trouble free, have had recurring issues w/multifuntion switch involving headlights. First time around cured by cleaning lighting plug connector, few months later replaced MFS. Had low beam headlights go out again, replaced switch but lighting connector plug was so brittle, it crumbled to pieces upon removal. Got another plug from salvage and changed out plug (quite a chore as the terminals were retained by plastic tabs that mostly broke off) and after plugging in and verifieing all operations, secured wiring w/silicone. Now 6 months later have lost low beams again, checked wiring to be sure terminals had not seperated, found replacement plug becoming brittle but wiring ok. I am assuming new switch is now bad but plug (22 pin) is too brittle to change out switch again. Does anyone know of a replacement plug available any way other than salvage or new (cost prohibitve) harness? Also during troubleshooting could not locate headlamp relay, nothing labeled as such in box under hood and removal of 2 relays under fuse panel inside had no effect on headlights, where am I missing it? THANX, Roger
Old 24 Mar 2014, 02:54 pm
Default Re: MFS Plastic connector issue
Fuses (dash) #19 and #20 (both 10 amp) control the low beams.
Dash fuse #1 (25 amp) and hi-beam PDC fuse #16/17 (15 amp) should be checked.
The head light relay is at the bottom of the fuse block (so is heated-seat relay). Head light relay is left side. The relay directs power to the low beam bulbs when hi-beams are engaged. It also kills power to fog light circuit when hi-beams are turned on.
All possible problem sources: MFS, fuses, relays, wiring connectors, bulbs, grounds.
Good luck
I need a connector Chrisd069 Classifieds: Want To Buy 25 27 May 2012 10:23 pm
Plastic guard under front right side is hanging// strut issue too thinkinboutit General PT Cruiser Discussions 5 19 Dec 2010 09:06 am
Connector removeal afaszholz General PT Cruiser Discussions 1 16 Aug 2010 02:13 am
ipod connector for 03 GT strangelove General Turbo Discussions 13 02 Mar 2006 06:48 am
ipod connector Neo Ion strangelove Sound and Security Forum 2 05 Nov 2005 05:21 am
