Electrics not turn off
  • 1 Post By randyincctx
Old 24 Mar 2014, 06:08 pm
Default Electrics not turn off
Hi,
I have a 2003 PT Cruiser. The plugs and wires are all new, (3K miles). When i turn the engine off the wipers, lights, and any other accessories stay on.
I've also had a problem with the vehicle drawing power off the battery when it is not running.
How do I trouble shoot for the cause of the electix continuing after I turn off? Is it likely that the problem with the wipers etc staying on is also the cause of the drain on the battery?
Thanks,
Jon H
Old 24 Mar 2014, 09:49 pm
randyincctx's Avatar
Lightbulb Re: Electrics not turn off
You didn't mention it,but does your PT Cruiser have factory fog lights???
Whether the answer was yes or no,I would still say based on your explanation,more than likely your MFS may be bad/going bad,and that's the first thing I myself would look to as the source of the problem.
Other than that;When you say 'turn the engine off',do you mean off and key removed,or off in the ACC position?
If the 'key on' electronics are continuing to work after the engine is turned off,and the key is removed......The source could be in the ignition cylinder,actuator,or switch.
If you have a multimeter you can check (or probe) the specific connections on those items for voltage & continuity,with the 'key-on',and then 'key-off'.
You should be able to narrow it done fairly easily by doing the things I've mentioned.
Aka:~KILLER~
Old 25 Mar 2014, 09:11 am
Default Re: Electrics not turn off
Thanks Randyincctx,
I will check the fog lights as they are original to the vehicle.
When I said "turn the engine off' I meant turn the key off, remove it and go to bed for the night.
I can check the ignition cylinder & actuator. But when you write check the 'switch' do you mean the switch to the specific electrical item- wipers, indicators, etc...
JH
Old 25 Mar 2014, 04:48 pm
Handy_Cruiser's Avatar
On the PT, the actual ignition switch is a separate part from the cylinder. It will be on the left side of the column across from the cylinder.
Old 26 Mar 2014, 12:25 pm
Post Re: Electrics not turn off
The ignition cylinder,and actuator are mechanical parts;When I say ignition switch,I'm referring to the electrical portion as seen in this photo:
Aka:~KILLER~
Electrics/ switch problem - computer thinks a door is open Jargo Tech & Performance Forum 14 21 Oct 2014 04:24 pm
Gremlins in the electrics 289must Sound and Security Forum 3 04 Dec 2013 02:38 pm
Strange Electrics Deanob Tech & Performance Forum 14 30 Mar 2012 07:19 pm
all the electrics went crazy!! flyeguy PT Cruiser Convertible Forum 4 29 May 2010 08:18 pm
Does not start (no ignition / electrics OK) - HELP!! aljimtom Tech & Performance Forum 6 30 Dec 2009 11:13 am
