Vibration problem
Like Tree4Likes
Old 25 Mar 2014, 09:48 pm
ddpianoman's Avatar
Default Vibration problem
I just bought a 2006 PT Cruiser Base model. It is in great shape and looks like new (almost!). It runs real good and is fun to drive, but I took on a 230 mile round trip this week and it was the 1st time I was able to really cruise at a higher speed. I noticed it had a vibration starting at my accelerator pedal that shook my leg and seat after 60, but only when I gave it gas. For instance if I was cruising along at 65 without having to give it any pedal, it was fine, but if it started to slow down and I wanted back to 70, it would shake the more gas I gave it til it was uncomfortable. No shake downhill at all. I took it to the dealer and they said it needs a rear axle. Does that sound right? I'll it back get tomorrow and will find out if it feels better, but I just don't know. Your thoughts please! Thanks.
Old 26 Mar 2014, 09:44 am
Default Re: Vibration problem
Sounds like a problem in the front/rear drive axles or CV Joints. You need to get it up on a hoist/lift and have someone below look at the drive gear as it's moving. Also check the CV boots for cuts or breaks that would allow dirt and debris to get in.
Re-read your post:
If the dealer already told you it's the rear axle and you don't trust them, get a second opinion.
Welcome to the forum.
Old 26 Mar 2014, 10:24 am
I don't follow the rear axle cause, given your description that it is directly engine-dependent, and since the rear axle has no engine linkage, I don't see the relevance.
I assume it's an automatic?
Could be lots of things -- transmission or transmission mounts, engine mounts, half shafts as Crewzin noted,... I just don't get how rear axle would not be causing the vibration whether you were giving it gas or not, since rear axle is just "along for the ride".
Old 26 Mar 2014, 11:39 am
randyincctx's Avatar
Lightbulb Re: Vibration problem
Since it seems to only happen upon excelleration,I'm thinking the torque struts need to be looked at for worn bushings/inserts.
One easy way to see if they're really,really bad.....Open the hood,and watch the engine,while someone revs the engine,and also with the brake applied,cycle thru the gear range(on ATX) ......Does the motor lurch forward excessively???......YES=Bad Torque Struts/NO=Keep looking
Aka:~KILLER~
Old 26 Mar 2014, 08:13 pm
ddpianoman's Avatar
Well I got it back and they said both axles were bad and needed replacing. They did it for free and I just drove it 200 miles. It was much better. It still seems a little bit too much vibration at times, but most of time it feels fine. I think it may be the road or the brand of new tires they put on it. (Regul tires).. Anybody ever heard of them? They have a nice look to them.
randyincctx likes this.
Old 12 Apr 2014, 07:32 am
ddpianoman's Avatar
Still got vibration. Steering wheel is not vibrating, but on a log trip my leg gets numb from the shimmy and vibration, especially when taking off up to about 25, then between 55 and 60, its not smooth. I cruise best at about 70-75. Taking it back to the dealer again Weds. They replaced the axles for free and say they will make it right. Any thoughts?
Old 12 Apr 2014, 07:41 am
By both axles, I think they mean left and right front.
Let us know when you get it back.
Never heard of those tires - a defective tire can give you vibration - but no point guessing- keep taking it back 'till they fix it.
Old 12 Apr 2014, 08:13 am
Perhaps you have the vibrating seats on?
Old 12 Apr 2014, 08:31 am
boonie2's Avatar
Are you EVER helpful , or just enjoy being Sarcastic ?
2004 Pt Cruiser 2.4 L {non turbo} 113K miles , Electric Blue pearl {PICTURES in my Profile Album}
Full Synthetic Oil 10w30 K&N Filter
Full Synthetic Trans Fluid / filter Change :bolt-away
Old 12 Apr 2014, 08:56 am
2step's Avatar
Speed dependent vibrations can have a number of causes. Common wheel balance or bent rim problems can be checked by switching the tires/wheels with the fronts to the back to see if the issue also "moves". Usually worn or failed motor mount/torque arm bushings are felt on acceleration but I suppose they can also occasionally be a problem at speed. The lower control arm bushings are another "usual suspect".
newbe thanks for solving vibration problem and a suggestion for oil light fix. ptprice General PT Cruiser Discussions 1 10 Nov 2012 09:23 am
Vibration at 70 mph Brunoka Tech & Performance Forum 5 19 Jun 2012 07:36 am
Vibration between 40 & 60 mph???? anyone had this? gtbright General Turbo Discussions 10 16 Jul 2005 03:06 pm
Vibration junkno General PT Cruiser Discussions 15 02 Nov 2004 08:57 am
Vibration!!!! 2003ptcrusierbrusier Tech & Performance Forum 8 05 Jan 2004 08:45 pm
