Engine Swap
Old 27 Mar 2014, 01:05 pm
Default Engine Swap
Hello, what are the differences in a 2002 2.4 and a 2004 2.4 the salvage yard says there are something different but they don't know what it is. Thanks
Old 27 Mar 2014, 01:12 pm
Default Re: Engine Swap
For one thing, the EGR system is completely different. The 2002 has the EGR tube in the back of the upper manifold and runs down to the EGR itself. The 2004 did away with the tube altogether.
The big thing that moved is the Crankshaft position sensor. In 2002 it was in back of the engine above the oil filter. In 2004 they moved it to behind the starter on the opposite side of the engine.
Old 27 Mar 2014, 02:58 pm
Also the computer won't recognize the correct timing of the other motor. So you will need to get 01 to 02 motor.
engine swap luckybadazzboy Tech & Performance Forum 16 11 Aug 2016 12:10 pm
engine swap jondickson Tech & Performance Forum 9 20 Apr 2013 01:36 pm
Can I swap a 2001 w/egr engine for a 2002 engine w/o egr? cas0918 General PT Cruiser Discussions 5 15 Feb 2013 11:58 pm
02 engine swap murphy Tech & Performance Forum 2 11 Dec 2010 12:44 pm
engine oil pan swap cruizinla Tech & Performance Forum 2 13 Oct 2009 07:32 am
