fault code question
Old 27 Mar 2014, 02:34 pm
Default fault code question
Greetings, PT'ers! Just got 2 fault codes and I am wondering if one relates to the other? Codes are P 522 and P 137. I know that one is for a defective oil pressure sensor, but I am wondering if the other is also related to the pressure sensor. Thanks for any assistance!!
Old 27 Mar 2014, 02:37 pm
Default Re: fault code question
You know you can always google the codes
OBD2-OBDII Engine Light Trouble Codes Definitions, Description and Repair Information | Engine-Codes.com
Old 27 Mar 2014, 02:50 pm
Yes-that's where I got the info on what the codes were-I am just wondering if one relates to the other. Thanks!
Old 27 Mar 2014, 03:44 pm
P0137: o2 Sensor Circuit Low Voltage Bank 1 Sensor 2.
Shouldn't have anything to do with the Oil Pressure sensor code. BTW, the PT only has one Bank so it's pointing to sensor 2 which is by the CAT.
Old 28 Mar 2014, 01:11 am
randyincctx's Avatar
Lightbulb Re: fault code question
Yeah....Replace your oil sensor,and your downstream(#2) O2 sensor,those codes should go away.......I would also recommend using only Mopar replacements,but you can use aftermarket(Dorman,Bosch,etc?),and if either of those codes returns,more than likely it'll be because the aftermarket part failed.
Money saving tip(s): You may want to check/clean-up the electrical plug for the #2 O2 sensor,the code could possibly be caused by just a faulty connection.
The OP sensor could also be checked/cleaned the same way,but it can sometimes back out (come loose) of the fitting,and cause the code.
But,depending on the exact age & mileage of your PT,it may just be time for replacements,as those are regularly serviceable/replacable parts.
Aka:~KILLER~
fault code P0195 ptcruiser973 Tech & Performance Forum 1 04 Feb 2014 12:44 pm
fault code flourman Feedback and Support 2 06 Mar 2011 08:10 am
Still getting a P0304 Fault Code????? caballero77 Tech & Performance Forum 14 01 Feb 2011 08:31 pm
Fault code P0685 martyd1972 Tech & Performance Forum 2 16 Jul 2009 01:41 am
Fault code RossiePT General Turbo Discussions 8 28 Mar 2004 10:52 pm
