2009 Base PT Cruiser Cooling Fan Issue
Old 02 Apr 2014, 01:16 pm
Default 2009 Base PT Cruiser Cooling Fan Issue
I have a 2009 PT Cruiser and I noticed that the cooling fan isn't running. The car runs fine without it until I turn on the AC and sit idle at a stop light. I replaced the cooling fan relays thinking that would fix it, but it didn't. The strange thing is when I took out a relay(Which is in near the cooling fan), the fan starts running fine. Any idea what's going on?
Old 02 Apr 2014, 02:32 pm
cruserdad1976's Avatar
Default Re: 2009 Base PT Cruiser Cooling Fan Issue
not really but if it were me Id just get the entire fan off ebay they are cheap replace it and see if that fixes it---YEs i knwo the relays should but in a lot of cases they dont then they will change the fan and BANM it works
Old 02 Apr 2014, 03:01 pm
" The strange thing is when I took out a relay(Which is in near the cooling fan), the fan starts running fine. Any idea what's going on?"
THAT is strange. You have the CANBUS (2006 and up) - try disconnecting the battery and stepping on the brake pedal (to drain residual charge) and see if that changes anything.
2009 pt Cooling fan has me perplexed jstnmlls Tech & Performance Forum 10 04 Jul 2015 06:49 pm
2002 PT Cruiser 2.2 CRD COOLING ISSUE Danny140986 General PT Cruiser Discussions 13 05 Dec 2012 03:45 pm
Heating cooling issue.....help? pluminator Tech & Performance Forum 1 14 Oct 2012 01:30 pm
Cooling fan issue torsotext Tech & Performance Forum 2 05 Jun 2011 07:30 am
Parting Out 2005 PT Cruiser base base model taftboys Classifieds: For Sale/Trade 9 07 Oct 2010 07:13 pm
