Engine bucks, stalls and restarts. Please Help!!
Old 03 Apr 2014, 02:06 am
Artur's Avatar
Default Engine bucks, stalls and restarts. Please Help!!
Suddenly started bucking on a road, no reacted on accelerator, rpm around 2000, then when I stopped the car engine stalled... 0513, 0201, 0202, 0203, 0204, 0032, 0038 done. Its possible to restart engine in 1-5 minutes and drive 30 min to the next stop.
Old 03 Apr 2014, 07:24 am
Artur's Avatar
Default Re: Engine bucks, stalls and restarts. Please Help!!
after filling up the tank Check goes off
Old 03 Apr 2014, 07:53 am
Does it run smooh after that or still having running problems? Skim key code issue could be the cause of the rest of the codes. Cutting off the fuel. You might have a pcm problem.
Old 03 Apr 2014, 08:09 am
Artur's Avatar
after filling up the tank car runs nice and easy, then Check comes on again , sometimes blinking but car can run without problems
Old 03 Apr 2014, 08:14 am
Same codes come back? In particular the P0513. Or have you cleared them?
Old 03 Apr 2014, 08:24 am
Artur's Avatar
- O2 sensors were checked by mechanic- replaced lower sensor because of wrong position of connector
- upper one was scanned and found good;
- catalyst was found burnt inside-it could be seen when sensor was removed an empty space was inside;
- no catalyst available now, so all mesh was removed from inside
Old 03 Apr 2014, 08:28 am
Artur's Avatar
Programming of pcm was done but on my way back home 0032, 0038 came back plus 0425 - thats what i have now. engine bucked and stalled again once.
Old 03 Apr 2014, 08:31 am
I'm more concerned about the skim key code. If the car does not recognize the key it will shut of the fuel pump. Maybe someone else has some ideas.
Old 03 Apr 2014, 08:44 am
Artur's Avatar
I could drive car all day long without any problems... but sometimes it happens
after garage service I made 50 miles before it happened...
Old 03 Apr 2014, 09:08 am
Artur's Avatar
forgot about 0300...
last time engine stalled and
now i have 0425, 0300, 0032, 0038 but i could drive home without towing... engine just started like nothing happened
Engine Stalled, Bucks bjagd02 General PT Cruiser Discussions 4 14 Mar 2014 10:18 am
chk engine lit comes on car stalls wont start mammothskibum General PT Cruiser Discussions 1 23 Jul 2013 12:08 pm
05 doesnt like to start then sputters bucks NO check engine light on??? racyred426 Tech & Performance Forum 0 16 Apr 2011 09:24 am
Loud Pop then engine stalls golddust General PT Cruiser Discussions 4 18 Nov 2010 07:50 am
engine stalls or stutters while in idle or stopped with a/c on, but not with a/c off traumadude376 Tech & Performance Forum 6 12 Aug 2008 12:15 am
